cent locking prob **update Brian**
blingsta
Boost Junkie
Post Wed Oct 19, 2011 10:15 pm
91 H reg cabby..
sit in the car, doors shut. press the locking pin down (drivers)and only the drivers side locks ?
lock the door with the key and all the locks work ?
i dont remember my other cabbies being like that !
correct me if im wrong, but if you press the lock pin down, shouldnt all the locks activate? i wonder why it only does it with the key ?
any suggestions pls?
kolee
Post Wed Oct 19, 2011 10:20 pm
sounds like a job for....WD40 MAN!
Electrical connections get very dirty and corroded over time. this can break the contacts. clean it all up first, see how you go.
blingsta
Boost Junkie
Post Thu Oct 20, 2011 10:11 pm
^^^ but why would the electrics carry through when the key is used and not when you push the pin down yourself?
Post Thu Oct 20, 2011 11:40 pm
When you lock it with the pin, do you get any assistance from the central locking?
blingsta
Boost Junkie
Post Fri Oct 21, 2011 7:58 am
no Brian.. just the pin i press down goes down.. nothing else activates.. central locking only activates when i use the key in either door or boot.. that tells me the micro switches are avtivating the central locking but not when you press the pins down manually ?
Post Fri Oct 21, 2011 8:53 am
Not quite the usual symptoms, but try a slight adjustment of the position of the lock motor. It's just under the front edge of the door card, and held in place in slotted holes by a couple of 7mm self tappers.
blingsta
Boost Junkie
Post Fri Oct 21, 2011 9:11 am
i think i get the idea !! pin maybe not travelling far enough to activate the locking system ?
i will report back with my findings
**BANNED**
Post Fri Oct 21, 2011 11:55 am
May be a good idea,whilst you have the door card off,to have the latching gear out and clean and lubricate it.I have found that they go stiff over time,leading to a damaged lock barrel....
Youth is wasted on the young.
blingsta
Boost Junkie
Post Fri Oct 21, 2011 12:14 pm
Thanks mate. Will do
blingsta
Boost Junkie
Post Fri Oct 21, 2011 5:48 pm
no joy Brian... still no activation when the pump is done by hand...?? only works with the microswitch ( key ) !!!
ive checked the connections to the pump, all appears ok? should there be any power in the plug that connects to the pump?
Door loom appears all ok!!! cant get my head round why it only activates on the microswitch??
**BANNED**
Post Sat Oct 22, 2011 1:54 am
So operating the c/l solinoid does not trigger the other locks?
blingsta
Boost Junkie
Post Sat Oct 22, 2011 5:53 am
Nope :cry:
**BANNED**
Post Sat Oct 22, 2011 10:21 am
Looks like your fault is either the c/l solinoid or the connection at the A pillar plug....you have done the red/black wire mod?
More help here;
http://www.e30zone.net/e30zonewiki/inde ... g_problems
blingsta
Boost Junkie
Post Sat Oct 22, 2011 11:03 am
red/black wire mod hasnt been done ! that will be my next step, but i dont think it will solve the problem..
i took the connection off at the A pillar yesterday and checked the state of the pins, all seemed good and no corrosion on pins.. i really dont think it will be the soloenoid as it works with the key !!! thats whats throwing my off that idea..
further to my findings........... the central locking activates all the locks when the key is used on only the drivers door and the boot... when you use the key on the passenger side, it only locks the passenger side door? im starting to lose a bit of hair cos im scrating it so much !! :?
Post Sat Oct 22, 2011 1:30 pm
All very strange! Try disconnecting the micro switch (dead lock switch), clamped to the lock barrel, in case it's giving a false signal.
blingsta
Boost Junkie
Post Sat Oct 22, 2011 1:36 pm
will try that when i get home from work Brian..
passenger or driver side? i might aswell tug them both off and see what happens..
Post Sat Oct 22, 2011 1:49 pm
Deadlock switch is only on the driver's side. The similar switch on the passenger door is used to set the locks, rather than the switch in the locking motor. Unlocking is still done by the lock motor though.
blingsta
Boost Junkie
Post Sat Oct 22, 2011 1:57 pm
ok.. thanks.. so just tug off the microswitch on drivers side and come back to report findings :D
Post Sat Oct 22, 2011 2:03 pm
blingsta wrote:ok.. thanks.. so just tug off the microswitch on drivers side and come back to report findings :D
Round two pin plug and socket a few inches from the switch>
blingsta
Boost Junkie
Post Sat Oct 22, 2011 2:58 pm
Hmmm !! i'll double check later, but im pretty sure i dont remember seeing one there yesterday when i was having a look
blingsta
Boost Junkie
Post Sat Oct 22, 2011 8:53 pm
update Brian ***
2 pin plug disconnected... key does not activate cent locking...
re-connected... key activates all the locks, but back to square 1, if you push the lock pin down, only the drivers door locks ?
next check please Brian :?
rskools
Post Sat Oct 22, 2011 9:01 pm
sorry to invade a forum but would anyone know why my e30 cabby locks it self when i shut the door and also when it doesnt lock itself i open the boot and and the central locking starts going crazy on both doors?.......weird any help will me much appreciated :mad:
blingsta
Boost Junkie
Post Sat Oct 22, 2011 9:06 pm
sounds like a dodgy module maybe? located behind the drivers side front speaker
blingsta
Boost Junkie
Post Sun Oct 23, 2011 5:09 pm
ive been fiddling about and noticed a few things that might help Brian..
when i lock the doors with the key from drivers side, everything locks. so far so good !!
if i lock the car via the boot, central locking activates as normal and by leaning in and using either doors handle will unlock the system again? so the boot lock is working fine !
i unplugged that 2 pin plug yesterday as you suggested and that resulted in the locks not working when the key was used in drivers door ????
what does this mean Brian?
blingsta
Boost Junkie
Post Tue Oct 25, 2011 10:32 am
Anyone ? :(
Post Tue Oct 25, 2011 7:24 pm
Sorry! Been a bit busy lately, and haven't had time to follow up some of the threads I'm involved with.
Seems like the 'lock request' switch in the driver's door lock motor isn't working.
Has this fault always been present or just developed? Could your car have been fitted with the wrong lock motor?
blingsta
Boost Junkie
Post Tue Oct 25, 2011 7:30 pm
Been like that since I've had it Brian.. The pumps both look OE and un-tampered with, likewise the wiring/loom.. The car was sitting for a very long time before it was put back on the road by me though? Could that have anything to do with it ?
blingsta
Boost Junkie
Post Tue Oct 25, 2011 7:35 pm
Should there be any live feeds from the loom that plugs into the motors?
Post Tue Oct 25, 2011 7:52 pm
The yellow/blue at the lock motor is the lock request wire, and the request is sent to the ECU by earthing it. On all the lock request switches on the car, except for the driver's door lock motor, this connection is straight to earth, but on the lock motor in question, the yellow/blue is connected by blocking diodes to both the blue and the white wires which power the lock motors themselves. Both these wires are earthed by the relays in the locking ECU when it is at rest.
blingsta
Boost Junkie
Post Tue Oct 25, 2011 9:02 pm
Ok, so if I was to disconnect the connection on the motor and earth the yellow/blue wire, should it activate the locks?
What should be my next test please ?
Post Tue Oct 25, 2011 11:31 pm
It should indeed!
Next test? Ideally, try a known good driver's door lock motor in there.
blingsta
Boost Junkie
Post Tue Oct 25, 2011 11:41 pm
Lovely.. Will do Brian.
I will unplug and earth the wire to make sure it locks up.. Will update with result..
blingsta
Boost Junkie
Post Thu Oct 27, 2011 5:13 pm
day off tommorrow and hoping to get this sorted.. 1 quick question Brian.. before i travel to mateys to get another solenoid to try.. i am going to earth the yellow/blue lock request wire. what happens if the c/l still fails to activate? where do i go from there?
blingsta
Boost Junkie
Post Fri Oct 28, 2011 2:34 am
been in the garage Brian, taken off the plug from the solenoid and earthed the yellow/blue.. Nothing happened?.. Tried the yellow/blue on the A pillar plug, nothing happened. Worked my way down to the central locking relay and earthed the Green/black which locks the doors and earth on
green/blue - unlocks ?? Nothing again on yellow/blue? What does this mean? :cry:
Post Fri Oct 28, 2011 9:50 am
Lock ECU has two lock request inputs (Yellow/blue and green/black), and two unlock request inputs (green/blue and yellow black).
The yellow/blue lock request and green/blue unlock request is used by both front doors, and the boot and rear doors use the others.
Does earthing the yellow/blue at the ECU set the locks?
