E36 hub setup
mrb27
Post Thu Oct 20, 2011 10:03 pm
hi all, i know this has been spoke about a few times but didnt have any luck with the search option so here we go again.
i understand that the E36 hubs etc are a direct bolt on mod with no extra parts required.
my question is with standard size E36 discs/calipers etc with abs being bolted onto a non abs car.. would this present a problem with brake lock-up? without looking at the size of the E36 brakes i would imagine that they are bigger? if so i would think that they have a lot more braking power.. making lockups easy with out the abs that it should have.. the only real reson for the swap is to open a lot more options for wheels.. not a lot of rims to my taste at 4x100 these days :(
Post Thu Oct 20, 2011 10:11 pm
E36 M3 EVO hubs and wishbones is what you need, standard E36 stuff does not align the wheel correctly.
Also, IIRC E36 ABS is not compatible with E30 ABS :?:
The 'proper way' of doing it is by using E30 M3 stuff but lots of ££££'s
HTH
Baurluvva
Post Thu Oct 20, 2011 10:18 pm
E36 abs can be spliced into e30 wiring so I have been led to believe.
(I am in the process of finishing my 5 stud swap with e36 bits)
mrb27
Post Thu Oct 20, 2011 10:25 pm
oh, i thought standard e36 setup would fit ok.. so being e36 m3 evo gear is needed.. sounds like ££££'s anyways. ive somewhat hit a stop sigh then :x
Post Thu Oct 20, 2011 10:31 pm
No you need the EVO wishbones to get the wheel in the centre of the arch.
Although I think I have heard of Treehouse bushes/wishbones being used with standard E36 stuff :?:
Grrrmachine
E30 Zone Wiki / Team Member
Post Thu Oct 20, 2011 10:45 pm
Everything you need to know is here:
http://www.e30zone.net/e30zonewiki/inde ... Conversion
