M20 sensor
Baurluvva
Post Tue Oct 18, 2011 1:53 pm
I have the m52 with 1sensor and an outlet in the head!
is it just a case of drill and tap in situ?
Will there be issues in doing this?
craigieeb
Post Tue Oct 18, 2011 1:59 pm
Temp sensor?
better off redoing the threads on the sensor it's self,
file the old ones off,
and re-thread it.. simples
Baurluvva
Post Tue Oct 18, 2011 2:12 pm
There is only 1 sensor on the head and one outlet pipe - the m20 temp sensor will have to go where the outlet pipe is...... Could I just put a short bit of pipe on the outlet with the sensor on the other end?
Green
Post Tue Oct 18, 2011 2:14 pm
Yeah you can drill the outlet and retap it, I'd have thought that's better then doing the sensor as it will make changing it if it ever goes bust a lot easier.
craigieeb
Post Tue Oct 18, 2011 2:15 pm
Yeah, it'll not be pretty but it'll work,
as long as it's touching the stub on the head (Think the sensor needs earthed??)
Baurluvva
Post Tue Oct 18, 2011 2:17 pm
Function over form ftw :D
craigieeb
Green wrote:Yeah you can drill the outlet and retap it, I'd have thought that's better then doing the sensor as it will make changing it if it ever goes bust a lot easier.
But drilling and tapping on a cylinder head thats already built up and bolted to the block, is a bit risky...
all it will take is 1 bit of swarf to get stuck somewhere it shouldnt, and it's game over,
1 over heating engine because the cooling system is blocked
Baurluvva
Post Tue Oct 18, 2011 2:55 pm
craigieeb
Post Tue Oct 18, 2011 3:01 pm
:lol:
Green
Post Thu Oct 20, 2011 2:49 am
Baurluvva wrote:There is only 1 sensor on the head and one outlet pipe - the m20 temp sensor will have to go where the outlet pipe is...... Could I just put a short bit of pipe on the outlet with the sensor on the other end?
For the sakes of a few quid get it machined down! The guy chucked mine in for free when he did my flywheel.
maf260
Post Thu Oct 20, 2011 9:07 am
I recently did mine myself. Put the sensor into a drill and used a file to remove the current thread then used a die to cut a new thread. Tap & die kit was £25 from Screwfix and will come in handly in the future I'm sure!
Post Thu Oct 20, 2011 9:18 am
Recut the thread is the obvious answer, it will cost a tenner pretty much anywhere, you have to be a real tight bstard to tap the head out whilst fitted! Its only do-able with the head removed so any swarf can be cleaned out properly
Baurluvva
Post Thu Oct 20, 2011 9:32 am
I'll mill the thread down. I'm not going to disturb a good seal on the head!
randomspeedfreak
Post Fri Oct 21, 2011 12:27 pm
ive just had the same issue and im also tapping the sensors thread.
ive been told the outlet is not needed anyway :)
