hi there, just getting my 325 up together
just wanted some info
Mine is a 325i with no power steering, and the steering is serissly heavy, ive pumped the tyres up to reduce friction but still extremely heavy, ive had older cars without power steering but this is crazy when parking, is this usual for these to be a nusance
also i guess i could just fit a power steering rack (is that possible)
also mine doesnt have central locking, am i correct all 325 came with cnetral locking and mine has been taken out, as it has no solenoids or ecu bit in footwell.
if i was to fit this would i need to get all these parts and recode key? (do i not need to bother with looms wireing etc)
and finally my e30 doesnt have electric windows, but when i was taking door cards off i noticed multiple connectors not being used, is it an easy job to fit as i have a centre section with the buttons in,
many thanks
JAck
325i model spec
kolee
What year is your car?
I went through your posts and seen a pic of a facelift e reg car. but looked like a preface conversion.
Your motor sounds either really under specced or someone went to town removing all that gear?
JC1989
ye its e reg. what do u mean a preface conversion? ill post a pic of it front and back, ye i think someone did go to town stripping it as i heard all e30 325 are meant to have central locking, give me 5 mins and ill post up some pics
JC1989
im pretty sure that is pre facelift am i wrong?
E30_Crazy
I've never owned an E30 with power steering. I guess I wouldn't have a fair opinion as to how heavy the steering is. I just always start the car rolling forwards/backwards before I start trying to turn the wheel.
kolee
A prefacelift should have chrome bumpers- hence "preface conversion" to plastic bumpers.
However i thought preface cars ended on d-reg and E-reg were all facelift motors (87 was the change over year). But then again, i dont think they are BMW bumpers fitted. And they are definaltely preface rear lights.
Mines an '86 and has powersteering, abs, elec windows and mirrors.
I would say someone has removed your standard spec. Cant quite see you interior but that doesn't look standard either.
JC1989
fer enuf, ive had mk2 golfs and other cars without power steering, but then again they didnt have a 2.5 lump wieighing the front down , i think i will get used to it, just ive got used to driving my gti-6 with light steering, i will man up lol
JC1989
oh k cheers kolee
ye its got zender front and rear bumper with m tec 1 skirts, ye interior has rear leathers and front leather from a e36, its not stadard by far
its defo a pre face then if its got prefacelift rear lights,
Power steering was an option on early 325i's
The crossover year for the facelift was 1987 - Facelift cars started to be sold towards the end of the Year so your pre-facelift E plate is likely to have been registered in Autumn/winter '87 although it may have been built much earlier in the year.
You can get a PAS rack & Pump setup off here or ebay for next to nothing - its well worth doing and makes the car a lot nicer to drive.
There is no Electronic coding chip in E30 keys to worry about - the locking mechanism is purely mechanical so you'll need the motors, looms etc - same with the electric windows.
It will be a lot of faff to retro-fit unless you plan on stripping the car as the carpet will need to come out to fit the electric window loom.
Worth giving your local dealer the VIN number to see what spec it left the factory with.
JC1989
oh k thanks, ye wud be good to do the power steering bit.
i did read up in fitting electirc widnows wihtout having to rip up carpets .
when i took my door cards off there where 3 different plugs inside the door, does this mean the electric window loom and central locking loom will be in the car> cheers
According to Glass's Guide, PAS and electric windows became standard in 09/88, and central locking in 09/86, but, apart from the PAS, only on models with a sensible quota of doors and/or decent engines.
PAS is a simple enough retro fit, involving reservoir, rack, steering coupling, pump, pipes, belt and pump bracket.
You may well have the locking/windows looms inside the doors if there are several spare plugs around, but might not have the body loom fitted. The locking and windows body looms are combined together and is separate from the main body loom. It mostly fits under the carpets at the front of the car.
Pull up the base of the gear lever gaiter. If the are rectangular plugs for the windows switches tucked under each side, then you may have the body loom.
Andyboy
- Alpina Colada
From 9/88, all E30's had central locking, green tint glass, power steering and front electric windows as standard. Central locking was standardised on the plastic bumper carsfrom the beginning (9.87).
Before that, electric windows were a £682 option, central locking £216, PAS £457. They really knew how to charge back then.
