Hi fellas,
My new 325i cut out whilst driving yesterday and now wont start!
The fuel pump is not running, but we have shorted out the Fuel Pump Relay and the pump starts. The DME relay and fuse 11 seem fine. (what does DMW stand for and what does it even do?)
We've checked the supply to the relay with the ignition on and its showing 11V to pin 86. Pin 85 which we assume is the Negative side, also shows 11V ?! and according to the haynes manual, this wire goes to the 'Speed Sensor Relay'. Does anyone know what that is and where its located?
From trying to work out the Haynes manual wiring diagram, Am I correct in saying, on the Fuel pump Relay:
Pin 30 goes directly to the + on the Battery
Pin 85 is Br/Gr and goes to pin 20 on the Speed Control Relay
Pin 86 goes to pin 87 on the DME relay
Pin 87 is Gr/V and goes to the Fuel Pump
So we think the fault is further on from the relay to the Speed Sensor or beyond?
Would anyone have any other ideas or advice?
cheers
dave
325i Cut out and won't start
daveburke114
- **BANNED**
I would be looking at the crank position sensor next,if this has stopped playing,the ECU thinks that the engine is not turning,so fails to switch the fuel pump on.
The CPS is positioned on the front o/s of later engines,and reads the toothed wheel mounted on the front of the crank.
On earlier systems,it is mounted on the bellhousing,and reads a peg mounted in the flywheel,these pegs have a habit of falling out...
Youth is wasted on the young.
