rear brake back plates
terrybmw
Post Sat Oct 15, 2011 8:59 pm
I have fitted a rear disc conversion to my car and found the hand brake shoes had fell off.it apears that the back plates have rusted were the pins that hold the shoes in.is it a big job to remove back plates.do I have to take the drive shafts or hub off or do the just un bolt.
fowler
Boost Junkie
Post Sat Oct 15, 2011 9:06 pm
if you remove rear disc you can acess the retaining bolts and remove the back plates think new ones can be purchased from the dealers :D
EX A-Tech Workshop bitch !!!
gone but not forgotten
harry_p
Post Sat Oct 15, 2011 9:10 pm
You'll have to remove the hub to change them, which means changing the bearing as it will break when you remove the hub...
That's the proper way anyway, I have heard of people cutting the old one off and cutting a slot in the new one so it can be twisted and bent past the hub, and welded back together once in place.
It's a very common problem.
cheers,
harry
mattycoops43
Post Sat Oct 15, 2011 10:50 pm
OR, it's so common a thing that many shoes come with little round plates that have a slot in them to reinforce that weak area. I am sure you can get them from somewhere. All you have to do is clip them over the end of the retaining pin and bobs your uncle etc.
1990 325i se "weinrot"-How did they know?
**BANNED**
Post Sun Oct 16, 2011 9:40 am
I modified a pair of big 'repair' type washers as a temperary fix about two years back :o:
Youth is wasted on the young.
Jozi
Post Sun Oct 16, 2011 12:42 pm
Anyone know where to get them round plates or what Daimlerman suggests? I re-painted my backing plates as they weren't to bad but a little additional reinforcement for the pins wont do any harm. I also stupidly fitted brand new bearings and then the hubs only to realise I forgot to fit the backing plates :( I'll be cutting a slit so I can twist them on and welding them back together then.
mattycoops43
Post Sun Oct 16, 2011 2:16 pm
Well, I bought a set of rear shoes for a peugot 406 estate, and they came with little plates that are a repair for when the hole weaken and split open. Obviously french cars rust faster!
I haven't needed any since, but they have to be available somewhere, I guess if all else fails contact the aftermarket shoe manufacturers to see if they will supply them on there own.
Post Sun Oct 16, 2011 6:55 pm
You just need some standard shoe retaining washers to go over the back of the pins-
http://www.ebay.co.uk/itm/LOCKHEAD-BRAK ... _532wt_907
Jozi
Post Sun Oct 16, 2011 8:14 pm
I'll try get them locally so, thanks.
terrybmw
Post Wed Oct 19, 2011 9:14 am
I have got new back plates now.so I will be cutting the old ones off and cutting the new ones.thanks for the advice
Post Wed Oct 19, 2011 9:19 am
Before you weld the backplates back together, after you've twisted them in place, check out where the handbrake shoes sit, and ensure you don't get a lump of weld there.
