temp on 316
gaszman
Post Sat Oct 15, 2011 10:18 am
the gauge stayed just above half new viscous fan is this correct
**BANNED**
Post Sat Oct 15, 2011 10:33 am
The temperature gauge shows a large range up to the first white mark and a short range between the three white marks,then a large range at the top of the gauge,there is a term for this but I cannot spell it... :o:
Say from 0 to 80,then 80 to 90,and 90 to 150,so the temp anywhere between the centre three white marks is acceptable,what is not acceptable is sudden un-explainable changes.
I would suggest that your radiator is losing efficency,not blocked,but the tubes are starting to get clogged up.Removing and 'back flushing' will help a bit,but Mr Moore does suggest that an E30 radiator should be an 100,000 mile service item.
Youth is wasted on the young.
Post Sat Oct 15, 2011 10:34 am
Marginally higher than most, but it depends on the rating of the thermostat you have fitted.
gaszman
Post Sat Oct 15, 2011 11:55 am
i havnt fittef a stat but will
