throttle sticking
VoodooX
Post Fri Oct 14, 2011 11:56 am
Hi Guys,
My throttle pedal has recently started to stick i.e. when pressing the throttle pedal and then releasing it the pedal does not return to it's original position, therefore, the engine rpm are higher than normal. I've cleaned out all the throttle body and checked it is working correctly but the pedal still gets stuck down. Do I need a new spring tensioner as the old one doesn't seem very strong or would it be something else?
Thanks,
Matt.
Post Fri Oct 14, 2011 12:04 pm
You need to remove the cable, soak it in WD40 and then 3 in 1 oil to get it running freely and then refit.
I did this with mine a few months ago and it makes a huge difference.
Getting the cable out of the bulkhead is tricky - just be patient. If the cable is frayed I don't think theyre that expensive new and a usable secondhand one should be easily available.
Topblag
Post Fri Oct 14, 2011 12:18 pm
Someone posted up recently that a new throttle cable makes a real difference to throttle response.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
Post Fri Oct 14, 2011 12:38 pm
Topblag wrote:Someone posted up recently that a new throttle cable makes a real difference to throttle response.
If its not frayed or damaged you can get it as good as new by soaking it in lube :chuckle:
Topblag
Post Fri Oct 14, 2011 12:44 pm
Make do and mend works for me !
**BANNED**
Post Fri Oct 14, 2011 12:52 pm
Throttle cable is a Bowden type with a nylon liner.
Now whilst removing and lubricating will help,for a while,once the self-lubricating properties of the nylon liner have worn out,replacement with a new cable is the only satisfactory long-term answer.Especially given the 'hassle factor' of removing the bloody thing at the pedal end.
Youth is wasted on the young.
Post Fri Oct 14, 2011 12:54 pm
I suspect the bulkhead clip is meant to be a "single use" item judging how fiddly they are to remove - not sure I could get mine out again without busting it.
Post Fri Oct 14, 2011 1:37 pm
daimlerman wrote:Throttle cable is a Bowden type with a nylon liner.
Eventually the inner wire will wear into the nylon on the tighter bends, making the cable operation stiff even if lubricated.
New cable is the way to go.
VoodooX
Post Fri Oct 14, 2011 5:36 pm
New cable it is then.
Thanks :P
BMW 1989 e30 325i 4 door - auto - Retired
BMW 1985 e30 320i 2 door - manual - Retired
