The engine on my 320 touring won't rev properly. I drove it from Stroud to Bristol absolutely fine Tuesday last week, went to start it Saturday and the car won't rev. First I thought headgasket had gone as when it first started it was running on about 3 or 4 cylinders, and then gradually cleared itself, like a couple of cylinders had coolant in (had this happen before on a different car). There was a little steam from the exhaust, but hardly a lot and it was cold so sure that was just condensation. Thats when I discovered it won't rev properly.
But then I started it tonight, it fired straight up and idled fine. But the engine just splutters and won't rev when you try and pull away. If you increase the revs very slowly when in neutral it will rev above idle fine, but not when you try and drive it.
The car has LPG, is a manual, and is on an f plate, LPG is not switched on, and the tank is empty anyway. My current guess is coil/coil lead/something up in the distributer cap. Or should I be looking elsewhere?
Cheers, Jer
m20b20 won't rev
torquey
I had the same problem,a pipe had come loose on the icv going in to the throttle body.
Bristol_Jer
Thanks, I'll have a check tomorrow, had a quick look over all the hoses earlier and they seemed fine, but I'll have a closer look.
lamby
worth checking fuel side to make sure its getting through,my fpr clogged and had same probs,like it was running out of fuel but tick over was fine.
Bristol_Jer
Thanks I'll check that as well when I get a chance. I only bought the car to use for a couple of weeks while my work van was off the road, going to have to try and sort something else now as I haven't got the time to sort anything major out on it
Bristol_Jer
All the hoses look fine to me, nothing loose. Have checked inside distributer cap and it all looks ok. Have swapped the coil lead for a known good one. Haven't tried swapping the coil for my other one yet, I'll try tomorrow.
Is this pretty much going to be down to something on the fuel side? I'm hoping I still have the fuel rail and FPR from my old b20 engine in the shed to try on this engine, but think I may have chucked it out
