E46 heater blower stop working
imye30
Got in my car this morning turn on the fan to de mist the front an nothing every thing lights up but no air even the fan speed setting shows speed what can this be
Ajsingh
Possibly a heater blower resistor. Common failure on e46's.. Its a metal spiked object that is located drivers footwell on the upper left part. Can be a right arse to take out
E30 Crazy!
blingsta
- Boost Junkie
yep.. as above, the classis hedgehog problem.. do the lights also work when keys out of ignition? could drain the battery
imye30
U mean the control lights for the blowerblingsta wrote:yep.. as above, the classis hedgehog problem.. do the lights also work when keys out of ignition? could drain the battery
pony
- I have been misbehaving and am sorry !
on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
the lights are off by the way.
100% it will be the final stage or "hedge hog". Its the heater blower motor resistor and they short out internally causing the fan to stay on intermittently which can cause a battery drain.pony wrote:on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
VERY common on E46/E39/E53, usually a stock item at BMW dealers.
pony
what is the final stage? Hedgehog you mean the heater blower motor i presume. Is it expensive/time consuming to get rectified?bss325i wrote:100% it will be the final stage or "hedge hog". Its the heater blower motor resistor and they short out internally causing the fan to stay on intermittently which can cause a battery drain.pony wrote:on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
Currently, the particular fuse for this circuit is taken out so it does not happen.
Its what i said it is!pony wrote:what is the final stage? Hedgehog you mean the heater blower motor i presume. Is it expensive/time consuming to get rectified?bss325i wrote:100% it will be the final stage or "hedge hog". Its the heater blower motor resistor and they short out internally causing the fan to stay on intermittently which can cause a battery drain.pony wrote:on mine the fan stays on (sometimes) even once you have switched ignitionoff - is that the hedgehog thing and what causes it precisely?
BMW call it the "Final stage"
Its common nick name is "hedgehog"
What it is, is the blower motors resistor, separate from the motor.
They are fiddly to change on E46's but not time consuming.
zaust
- Zone day release
