It was about a year ago that I did this but I'll give it a go:
You should have a 3 pin (C104) connector exiting your instrument cluster that looks like this:
This is where the pre-facelifts get their tacho and fuel rate signal from, but the facelift ones don't. So you need to cut the corresponding C104 connector from your old engine loom and splice it into the motronic 1.3 loom so the tacho can get it's signal back, connecting the following:
- Tacho - 0.5mm black on C104 to 0.5mm black from pin 6 JPT55 (ecu plug) connector
- Fuel Rate - Wht/yel on C104 to Wht/BK on pin 32 of JPT55 (ecu plug) connector
Here's the JPT55 pin layout fyi:
All this is info is taken from this thread:
>>clicky<<.
This sounds more tricky than is actually is, I managed it no problem at all and I'm no electrical genius.
HTH
