Water in the sills? Cabriolet
DazzyA
Post Wed Nov 09, 2005 8:54 pm
After clearing the drain holes in the roof compartment the water seems to be draining into the sills but not draining from them, i pressume i also have a blockage in them but cannot find a likely place, where should i be looking?
Pass me the spanner
325iconv
Post Wed Nov 09, 2005 9:49 pm
mine usually blocks up at the middle of the sill just run your hand over the back of the sill you normally dislodge the blockage then just prod with a thin screwdiver and it will run out and clean your hole.I recomend cleaning the hole every couple of months
DazzyA
Post Wed Nov 09, 2005 9:54 pm
thanks for that, had a quick feel, but will have proper look at weekend, sounds like theres about 10 gallons in there, very strange feeling.
cheers
Pass me the spanner
325iconv
Post Wed Nov 09, 2005 9:58 pm
YEP it s a bugger when that happens.sort it sooner rather than later as it kills the wires for the central locking relay,had to rewire mine as the wire corroded took forever to get right again
DazzyA
Post Wed Nov 09, 2005 10:14 pm
mines just started playing up!! I had the locks out and all sorts over the weekend DOH!
thanks agian.[img][img]http://img14.imageshack.us/img14/4751/c ... 6wl.th.jpg[/img][/img]
Pass me the spanner
BaggedE30
Post Thu Nov 10, 2005 12:18 pm
how does the water get into the sills? from the sunroof?
jpboost
Post Thu Nov 10, 2005 12:40 pm
There is a drain in each corner of the sunroof.
these sunroof drains run down and vent out though holes in the sills. When the holes get blocked the sill fills up...
oneblueleg
Post Thu Nov 10, 2005 1:29 pm
the water draining from my roof compartment comes out about 1/2 way along the sill.... a few inches under the car from the side
DazzyA
Post Thu Nov 10, 2005 8:31 pm
Had a good feel about today 8O seems that someone may have done a Rolf Harris underneath with a barrel of tar or something. I will get her in the air over the weekend and have a proper look, thanks for the direction oneblueleg.
baggede30, this is on a convertible mate.
Pass me the spanner
KDS
Post Sat Nov 12, 2005 12:35 am
Good old fashioned pipe cleaners work wonders clearing the holes. Good luck draining her out!
-KDS in Vancouver ('88 325i Touring)
