Brake discs......... which ones???
miniblob
Right, there is way too much choice out there!!!
It's a 2.7, standard brake setup, some track use coming up (and road use!!).
Probably gonna get EBC yellowstuff pads this time (heard some good things so thought I may give them a try!).
But which discs to buy........ do you really get a better disc for paying more??
Any recommendations???
Pagid £31.80
Apec £38.89
Mintex £48.40
Brembo £58.54
EBC grooved & dimpled £89.95
OMP grooved & Drilled £103.69
EBC slotted £134.94
(had black diamond before and they weren't up to much!!!)
So, any suggestions???
Pagid £31.80
Apec £38.89
Mintex £48.40
Brembo £58.54
EBC slotted £134.94
327 Touring with bass!!!
hongkongfuey
- Mad-tango-geezer
i had brembo discs, from gsf, good enough for fast road use, should be good enough for track, i used oem spec pads though, stay away from pagid they are crap, have these in at the mo in my 2.5 touring
with cars like mine,
miniblob
Was assuming Brembo & upwards to be honest!!
Just wondering if it's worth the extra cost to go to grooved/drilled/slotted discs??
Will they give any extra bite? Or less fading??
Any other suggestions, before I throw my money away???
Grooved/drilled/slotted boy racer stuff won't be any advantage at all. The purpose of the surface decoration was to allow an escape path for the gasses produced under hard braking from race pads, to avoid a 'hovercraft' effect pushing the pads off of the disc.
No pads that are in any way suitable for road use produce gasses these days, so plain surface discs are all that are needed.
A disc is just a lump of machined steel, so as long as it's made to OE spec, from decent material, then all discs are equal. Pagid are produced by Europe's largest manufacturer of brake components (TMD Friction) and are well up to the job.
Hongkongfuey: Pagid pads are OE spec. They supply OE pads to BMW. The last set of genuine BMW pads I fitted to my E34 were stamped Pagid-BMW. This is my towing barge, and the brakes get used seriously hard.
Andyboy
- Alpina Colada
To be fair though, neither Pagid nor Textar pads that are sold to the aftermarket are the same compound as ones in BMW boxes. But they're perfectly okay. I have Pagid discs on my Compact that's seen a few trackdays. I would add though that they suffer very badly from corrosion in the winter when the salt is down - the last set were destroyed by salt after being stood for 2 weeks.
I would also look at Ate discs as well as ones from BMW. EBC yellow pads are superb.
keri-WMS
We do plain 260x22 vented discs for £36.54+vat/pr, so Pagid have us beaten for a plain disc. There's no point getting grooved/drilled or anything like that.
Didn't know EBC had such a difference between grooved/dimpled and grooved - odd bunch at times!!!
miniblob
That's exactly what I wanted to hear!!!
Thanks guys!!!
Thanks guys!!!
miniblob
Just checked ECP again and found those Pagids are price per disc!!!!
So at over £60 pr they should be decent!!
Morat
I was seriously tempted by EBC Yellows last time round but I can't get consistent reviews.. some say they take ages to warm up others that they are perfect for road use. What's your experience?Andyboy wrote:To be fair though, neither Pagid nor Textar pads that are sold to the aftermarket are the same compound as ones in BMW boxes. But they're perfectly okay. I have Pagid discs on my Compact that's seen a few trackdays. I would add though that they suffer very badly from corrosion in the winter when the salt is down - the last set were destroyed by salt after being stood for 2 weeks.
Andyboy
- Alpina Colada
EBC yellows work from stone cold. I've used them on the road and trust, me they do not require warming up. They are basically a road pad but work well on track days.
Morat
excellent
Thanks!
edit: Bah, EBC don't list Yellows for E30s on their site
Thanks!
MJJ_ZX6RR
I fitted EBC yellows a few weeks back and agree with Andyboy, work perfectly from cold.Andyboy wrote:EBC yellows work from stone cold. I've used them on the road and trust, me they do not require warming up. They are basically a road pad but work well on track days.
Not used them on track yet.
Martin
Lots of bikes, the odd modern BMW, and now an 88 e30 335i Cab project with E32 running gear
keri-WMS
EBC are not so sure about Yellows from cold:
I've got them available here if it helps? http://www.e30zone.net/modules.php?name ... 9&start=24
hongkongfuey
- Mad-tango-geezer
To Brian, i dont care what spec u say pagid pads are, they are sh1t, they are in my car, please don't tell me they are good
In what what are they "sh1t"? I have a set in one of my tourings as well (from ECP), and while the brakes on this one don't get used anything like as hard as the ones on the E34, they still get a good caning around the lanes with no problems, other than a fair bit of dust.
Andyboy
- Alpina Colada
I use Pagid discs and pads - they are absolutely fine for a road car, even one that's driven hard. Never had any issues.
Dunno what EBC are on about on that chart, but are possibly covering their own back. they are a good pad - dust is an issue if you like clean wheels and they don't last as long as a regular pad but overall they're very good.
That chart could provide a get out clause for an insurance company trying to avoid a payout, if their assessor finds you are using anything on the road that doesn't go right to the LH side of the chart.
Brembo discs and Pagid pads work very well if the calipers are doing their job right,
hongkongfuey
- Mad-tango-geezer
ffs, i dont care what u have in ur car, they are the worst ones i have used, just cause u have them Brian, doesnt mean they are the best
groovylee
and, on the flip side, just because YOU had a bad experience with them, doesn't make them crap. i have used them for years, in several different cars, and i found them fine.
besides, brake pads are hardly a reason to get all worked up, are they??
Worst in what way? What characteristic of them don't you like?
"They are sh1t" is not a constructive post. "They are sh1t, because ...........", is.
mrb27
i brought some cheap discs once and never again, on the A12 one day faced with a pile up ahead.. braked from 80-0 no problem, getting off again was another matter. for the rest of the way home if i so much as tickled the brake pedal the front of the car felt it was about to fall of, the vibration was terrible due to the fact that the discs heated to a very high tempeture and warped so bad that a walkers crisp would have done a better job as a disc after that
imo we are talking about the most important part of the car and should never be compramised.. oem+ all the way. plz forgive my terrible spelling lol
Andyboy
- Alpina Colada
In what way are they 'the worst'? Do tell!hongkongfuey wrote:ffs, i dont care what u have in ur car, they are the worst ones i have used, just cause u have them Brian, doesnt mean they are the best
I don't recall anyone saying the were the best. They are simply standard brake discs made by a respected brake manufacturer to OEM spec.
miniblob
In case you haven't found it - I was told they are code DP4779RMorat wrote:excellent![]()
Thanks!
Not seen that chart before, but on the ebcbrakeshop.co.uk it reads:
'Although a full race material and capable of high temperature use with very good wear life, this new formulation sets a new trend in race type brake pad compounds. The bite from cold is superb which is uncommon with race materials (normally requiring warm-up) and makes this a pad which can be safely used on the road as well as on the race track.'
Morat
Good to know, thanks for the help
