only picked up the car last week
done a service and brakes
and today had it running for 30mins charge battery
but temp went right to the top? assume the fan should kick in at some point and cool it down
looking for some ideas please to cause
318 E reg
Engine getting hot hot hot
cjdonny
Easy one - same as my new cab.
Viscous fan coupling is dead. 32mm spanner, and don't forget it's a reverse thread.
cjdonny
Cheers will have to look up what it is i need to get
22sas
Hi m8 is your car looseing water?
cjdonny
Hi no but when it went right to the top a tiny bit came out from bottom pipe I think were filler cap is,but think that's more likly due to pressure build up.the fan is spinning but not. Very fast
318 IS
Reck
I got rid of the viscous bollocks altogether and went with a fixed fan from an E21..
That will do wonders for fuel consumption!Reck wrote:I got rid of the viscous bollocks altogether and went with a fixed fan from an E21..
Reck
You think it'll affect it noticably? I can't see it takes much to spin a fan. It's already having to spin the water pump on the same shaft which I would think constitutes the bulk of the resistance (water being thicker than air..).
I've also wondered how many horsies a fixed fan might be stealing.. BMW must have dyno'd the two at some point to decide upgrading to the viscous was worth it.
[edit] Just found this on a quick google.. Dunno how true it is. Fairly interesting though as I have considered switching to an electric fan lately..
VISCOUS CLUTCH FANS CONSUME NEARLY AS MUCH FUEL/POWER AS FIXED BELT-DRIVEN FANS
The viscous fan was not designed for economy or power saving but to provide greater low speed cooling without prohibitive power consumption at maximum revs. Cars using speed controlled viscous clutch fans absorb approximately the same power to drive the fan as a typical fixed-drive, belt-driven fan because they are larger and only slip significantly at top gear speeds well above 70 m.p.h. Temperature biased viscous clutch fans engage drive when the engine thermostat opens and allows heat to be dispersed by the radiator. Except in the unlikely event of the engine thermostat shutting, it becomes a continually driven fan for the rest of the journey making its removal essential to avoid unnecessary power loss.
Morat
Is this from some "ultra-mileing" site where they stick cardboard down their radiator grilles to save fuel?
Reck
No, from an electric fan retailer so perhaps not the most neutral of sources! If anyone has any links to something more reliable I'd be interested in reading them.
I only run a fixed one as a new viscous clutch was expensive (plus one of my fan blades was cracked) and a fixed one has built in 'redundancy' - there's not really much that can go wrong compared to the other two. I wouldn't be driving an E21 if I were that concerned with fuel consumption.
E30 viscous fan is temperature controlled, not speed controlled!
An electric fan that shifts the same amount of air as the standard viscous coupled one will absorb considerably more power than one that is directly driven. The viscous coupling has losses, but not as great as those in converting mechanical energy into electricity and then converting it back again.
cjdonny
Right so i need to replace this?
318 IS
Reck
Yes, either replace with another viscous fan/clutch assembly (probably best go for a new one) or replace with a static fan from an earlier M10.
