Head Inserts - Just Wondering
greggers
Just curiosity more than anything else, has anyone used these http://www.hutsonprecision.co.uk/automo ... -1183.html when doing a head gasket repair job... Would they be a better bet than risking the standard threads, or would you use these if you'd already killed your standard threads???
Jozi
When you strip the threadsgreggers wrote:Just curiosity more than anything else, has anyone used these http://www.hutsonprecision.co.uk/automo ... -1183.html when doing a head gasket repair job... Would they be a better bet than risking the standard threads, or would you use these if you'd already killed your standard threads???
greggers
Do you think their claim of doubling the strength of the threads sounds plausible?
It wont double the strength of the ally theads but screwing a bolt into a steel insert is better than screwing into ally. If the head bends it will pull the ally threads regardless of inserts
or no inserts IMO
or no inserts IMO
greggers
So if you were considering forced induction these could be a worthwhile upgrade.
Perhaps their claim is based on the fact that you are increasing the surface area of the whole thred.
