scary stuff cars got mind of its own!!!
ravstar13
Post Mon Oct 03, 2011 3:27 pm
just went to drop my brother to work and while driving the car seemed to accelerate by it self and done it round a corner to ...once i got to his place of work... I popped the hood and pressed the gas and it seemed OK and the throttle cable seemed to be OK too moved freely ...now driving home it done the same thing ...i figured how to stop it and that was by tapping the accelerator..it seems to do it more around changing gears but a few times did it while just driving ...got my self home but scared !!!can someone help...otherwise ill have to take public transport to work :(...ps its a 1990 316i lux m40
rover-2000
Post Mon Oct 03, 2011 3:32 pm
Sounds like a sticking cable. Only real solution is to replace it.
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
boxclever1753
Post Mon Oct 03, 2011 3:48 pm
smacks of christine... the only thing you can do is get the car crushed and scatter the bits at the ends of the earth... serious.
tha881
Post Mon Oct 03, 2011 3:52 pm
Check the accelerator pedal at the top, if it has moved to the right then push back left as far as it will go. Its kind of a linkage and if pedal gets kicked to the right can cause it to stick
cjdonny
Post Mon Oct 03, 2011 3:58 pm
boxclever1753 wrote:smacks of christine... the only thing you can do is get the car crushed and scatter the bits at the ends of the earth... serious.
:rolling: :teehee:
christo
Post Mon Oct 03, 2011 4:10 pm
Hi did you put your foot on the brake when this happend, because it maybe your brake server sucking in air as this is a problem that i had with my e30 a m10 engine hope this helps. cheers.
