Hi,
i m looking at changing the Rear brake hoses, up above the rear beam ,
is this posible with out removing the exhaust / undoing the rear shocks and droping down the rear beam down ?
any body got any tips on the easyest way to do it ?
thanks
Rear brake hose changing any tips ?
- **BANNED**
Drain of the brake fluid
Slice the old flexi as close to the furrule as possible
Use a 14mm socket on a suitable extension on the ferrule
11mm brake pipe spanner on the other side and pray!
When your prayer fails(and it will)...
Cut the front/rear pipe in a convienient place,and replace the lot from there back to the wheel cylinders.
Use a pair of pliers to lever the spring clips open so that the remains of the pipework can be pulled through the brackets.
Deep joy,this job....
Youth is wasted on the young.
Andyboy
- Alpina Colada
Yes, pay a garage to do it.petrol_1 wrote: any body got any tips on the easyest way to do it ?
thanks
It's an absolute bastard of a job unless it's had new metal pipes in a recent past. You will need a proper brake pipe spanner - an ordinary 11mm will just round off the unions.
petrol_1
Thanks for the replys , I like daimlerman idea of cutting the hose and using a shocket , but b4 i start
Ok scair me ,
whats a fair price to pay to get it done! as much as the cars it worth no doubt!
i ve been spraying penitrating fluid on it for days in the hope it may help, but this could be the end
Ok scair me ,
- **BANNED**
Even if you have to buy a pipe-flaring tool,a hand full of fittings as well as the flexi's,I doubt that you will spend £50...
A garage will charge at least £30 an hour,should take you a morning if you are laid on your back.
