non starter
fastdave
Tried to start one of my 325 tourer and not getting any fuel and cannot hear pump working. I was going to check relay first not sure which one it is ? Cheers
Grrrmachine
- E30 Zone Wiki / Team Member
When you turn the key, is the engine swinging over? And are you getting a spark?
If it's JUST fuel you're missing, start at the fuse (11), then check the relay (under its own cover on the passenger inner wing, it's the orange relay on the right side, not the middle). If they're good, it'll be the pump itself.
But if you're also not getting a spark, then chances are the Crank Position Sensor isn't telling the ECU to turn on the DME relay, which means neither the spark plugs nor the fuel pump are getting power.
So don't go swapping parts just for the sake of it, do some tests and report back.
And it's tourING, not tourER.
fastdave
Thank you will do checks on my touring
and get back Cheers dave
rover-2000
Tourer= Rover
Touring= BMW
I keep getting it wrong too, because I have had both.....
Touring= BMW
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
- **BANNED**
Fuel pump relay could be one of several colours,but one of the wires at it's bum will be green/violet!
To test the fuel pump,remove the relay and link the green/violet to the red/white with a short length of wire,this should make the pump run all the time.
Youth is wasted on the young.
