I decided it was about time I checked my tyre pressures today, and so I did the obvious thing and checked the sticker inside the door. There was no figure listed for the tyres I have fitted so it got me thinking - I may have the wrong size on?
I have the standard 15" Basketweaves, Running 205/50/15
Opinions? I'm not planning on changing them as they are nearly brand new, (although I will put the correct size on when it's time to change them).
What pressures should these at, and what is the correct size?
Tyre size?
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
Kos
205 55 is the correct size but 205 50 tends to have more choice and slightly cheaper for brands at the higher end of the market
pressure wise, its been a while since i had an e30 but about 30psi should be in the ball park
m8782538
30-34psi should be about right, normally 2-4psi lighter at the rear.
cee
The door sticker says to be lighter at the front
