e30 325i wont start
damian666
Post Thu Sep 29, 2011 7:22 pm
I have a 1990/91 e30 325i convertible. I just replaced the fuel pump and the fuel pump relay. the pump is pumping however the injectors dont seem to be working and ideas? thanks
Post Thu Sep 29, 2011 7:46 pm
There is a plug and socket fixed to the metalwork under the inlet manifold, where the injector loom joins the main engine loom.
If it hasn't been modified, in accordance with a BMW TIS, it tends to collect and trap water under its lower rubber boot, which rots through the wiring to the injectors.
damian666
Post Thu Sep 29, 2011 7:57 pm
it was running untill the fuel pump went wrong
