Helicoil? Re-Thread? What Do I DO?!
TheChin
Post Wed Sep 28, 2011 12:18 pm
Good afternoon,
One of the manifold studs on the M20 has stripped completely out of the head. I've tried to locktite it in; as there was 2 or 3 threads; but they have now gone aswell.
What do i do? Do i re-thread it to a bigger size and use an oversized stud? Someone suggested Helicoil but I can only find a kit for 20 pieces when I only need one!
Any help would be greatly appreciated :)
TheChin
4 Door E30 325i, JOM Coilovers, OG Axis Wheels
wullie325i
CAUTION - unreliable trader!
Post Wed Sep 28, 2011 12:27 pm
a tap and die set. run a tap in the hole and get new studs ect and all should be well.
TheChin
Post Wed Sep 28, 2011 12:35 pm
So if the stud was M8; i'd go for an M8 tap and die set?
TheChin
Post Wed Sep 28, 2011 3:43 pm
A bag of 20 helicoils is about £4, are you really that tight? :eek:
TheChin
Post Wed Sep 28, 2011 4:00 pm
No; but i haven't got any other tools so having to buy the kit ends up at £30.
How do i set them? Tap to the exterior of the helicoil and match the interior to M8?
TheChin
Post Wed Sep 28, 2011 6:55 pm
£10.50 for the tools and 25 helicoils here - http://www.ebay.co.uk/itm/25-Piece-Thre ... 909wt_1348
Rodderz
Post Wed Sep 28, 2011 7:00 pm
You should get a tap with the kit which is the outside thread of the helicoil. You run the tap down the hole, and then wind in the helicoil, which then provides the M8 thread that you need!
clipper
Post Wed Sep 28, 2011 7:06 pm
Without trying to sound patronising, are you sure that the stud won't wind in to virgin thread ?
One of mine went like yours but by putting a cocktail stick into the hole I realised that it was about 4-5 mm deeper than I thought. By hand the stud would only wind in by to the original depth, so I cut a slot in the end and wound it all the way in with a screw driver, then I got the nut to tighten to the specified torque without it pulling out, and there it has been for 3 years with no problems....
Rodderz
Post Wed Sep 28, 2011 7:09 pm
I thought he said there was thread remaining, but that stripped also!
TheChin
Post Wed Sep 28, 2011 7:41 pm
I replaced with a 4mm longer bolt but it's tightening then coming loose. So many shavings!
TheChin
