Top hose problems...
craigieeb
Post Sun Sep 25, 2011 6:37 pm
Yes me again,
yes still with problems with the M52 :-x
right here goes..
recently put the cylinder head back on after doing the headgasket,
all went together perfect with no drama's,
Bled the cooling system and it went like a dream, bled up straight away,
now after a few days of driving it, I checked the levels
and there was no water in the tank on the side of the radiator,
strange...
filled it, started to bleed it once again and after 2 days I nearly gave up,
but continued with it, and managed to get it done,
but ...........
WTF!!!
When I checked the car this morning, the top radiator hose was nearly sucked flat ???
this is a new one,
anyone know what the cause?
I took the cap off and the water level was spot on
Oh yeah temp needle stays bang on in the middle.
Any help before I frag it?
craigieeb
Post Tue Sep 27, 2011 6:30 pm
Bump..
Anyone know why my top hose is getting sucked flat?
Post Tue Sep 27, 2011 6:58 pm
Are you sure its getting sucked and not just deforming? Did it reshape after you took the cap off? Any whoosh of air? I cant understand how you could have a vacuum in the cooling system
craigieeb
Post Tue Sep 27, 2011 7:21 pm
DanThe wrote: I cant understand how you could have a vacuum in the cooling system
You and me both mate, it's a new one on me, and my mates,
and it is definitely getting sucked in once its cooled it's self down,
when i take the cap off there is a little "whoosh" and the pipe breathes/opens up a little
but not to its true form,
only if i take the pipe off it goes back to it original shape :?
I'll make it do it again and grab a picture of it
MurphyE30
Post Tue Sep 27, 2011 7:49 pm
Sorry to hear you still having troubles with the Donk mate, last i heard you was up and running ok
(sorry nothing helpfull to add :mad: winkeye )
randomspeedfreak
Post Tue Sep 27, 2011 9:11 pm
just a guess but maybe something in the heater matrix is slowing the flow?
if you figure out which way the water is flowing might give you an idea?
craigieeb
Post Tue Sep 27, 2011 9:46 pm
the matrix has been bypassed,
there are no leaks anywhere
and the water is circulating.......
duff pipe?
It was ok before the headgasket went....?
Post Tue Sep 27, 2011 11:42 pm
Try a different pressure cap.
craigieeb
Post Wed Sep 28, 2011 1:04 am
The one that's on, is a new one from the dealers,
I'll try one of the old ones iv got lying about,
leeparkes
Post Sun Oct 02, 2011 10:55 pm
Did you sort this?
craigieeb
Post Mon Oct 03, 2011 3:27 pm
You know what... I think I did :)
changed the cap, and it seems to be behaving it's self,
........ for the time being
wonder if I got the caps mixed up when I bought the new one :mad:
leeparkes
Post Mon Oct 03, 2011 9:38 pm
8)
