m50 misfire can any1 help.
jonnyboy
Post Sat Sep 24, 2011 10:29 pm
hi, ive got a e36 2.5 m50 engine it was fine i give it new plugs and filters, oil etc. but the day after it ticks over fine but seem to be holding back and have a missfire when on load.ive Had a look over everything seems ok ive have a look at the coils and number 2 was down so bought a new 1 then number 6 went down so i put number 6 into 1 and 1 into 6 it ran fine for 5 mins then missfire come back, so i unpluged the coil one by one and it showed number 3 was down and number 1 and 6 was fine.
Has anyone had this before any common thing i should b looking for thanks guys
emdog16
Post Sun Sep 25, 2011 9:22 am
I have had so many coils burn out on bloody m50's. There could be an underlying cause I don't know about which I would love to hear about. But for now... I say m50 coil's should all be upgraded :)
Avid E30 Nut, and Scientist of all things that go BOiiiNGGGG.
If you want to go mental on your shocks... check out ForRacingUseOnly.com
jonnyboy
Post Sun Sep 25, 2011 1:50 pm
ive been offered a set of coils out of a p reg 328i will these fit my m50 325i.cheers
Post Sun Sep 25, 2011 4:00 pm
M52 coils have different mounting locations, I have a set of perfect M50 coils in the FS section for £35 posted
jonnyboy
Post Sun Sep 25, 2011 9:26 pm
when i pulled the coil packs out the first time 3 of the plugs was covered in oil could this have something to do with it and does any1 know why it would be covered in oil. cheers
Post Sun Sep 25, 2011 9:36 pm
Because oil is leaking past the cam cover gasket
