Would it benefit me to brace anywhere else?
Pics-
I was thinking about this and couldnt decide, like ive said its only a bolt in cage so structural strength benefits will be minimal, I think such a bar would only benefit the rigidity of the car in a fully welded cage, so wouldnt be much use to me.gcs325i wrote:Would a brace between the base of the main hoop to the rear arch/harness bar area be beneficial or over kill?
Agreed.UweM3 wrote:Personally I don't like this boxes. I didn't want to have something with sharp corners next to my feet. Call me paranoid. My cage was welded with spreader plates right to the floor
Dan, see how Uwe mounted a short vertical piece of CDS directly over the points where the rear sub-frame bolts in place under the car. He then welded two diagonals to that tube, and then triangulated the whole thing in. That is well worth doing as it significantly reinforces two very critical points to which the rear sub-frame connects. A further requirement (imo) is to drop something from the frame/cage down to the differential.UweM3 wrote:
