Pilot bearing
xavier
My E30 has a bit of a judder on take off. I have been told it might be a warn pilot bearing. Also it's gear change has always been a bit notchy. Is it worth replacing the clutch and pilot bearing? I have changed the clutch in a hilux an the clutch aligning tool was easy to make up out of wooden dowel. Is the tool similar for an E30 ?
- **BANNED**
Is a 'pilot bearing' upsidedownspeak for a 'clutch release bearing?'
Could be the cause of clutch judder,I guess.
I made up a clutch alignment tool from a long bolt with gaffer tape wrapped around it.....
If your E30 has a 'proper' engine,unless you have access to a car lift you will struggle to reach the top bellhousing bolts,may,just,be easier to pull the engine and 'box out as a unit and swap the clutch on the deck.
Youth is wasted on the young.
eko
- Old timer
Pilot bearing = spigot bearing I believe.
xavier
I have never taken the motor out of a water cooled car(sorry past with old VWs). Are we talking days or weeks? It is a 323 and it is very cramped and awkward in the engine bay. There are about half a dozen jobs that I would not mind doing with the engine out.
I do not have a car lift, but I do have an inspection pit. Will this aid in getting the top bellhousing bolts out?
- **BANNED**
Engine out with a 6 cylinder E30 will take a half day the first time,you will get quicker with practice!
Problem with the upper bellhousing bolts is getting at them,stood under the car in a pit will be a whole lot easier than being laid on your back with the car on axle stands...dropping the back of the 'box down and being stood upright you may even be able to see the little buggers,and you will be in a decent position to slide the 'box on and off.If you do have a go from underneath,it's worth chopping the heads off 4 long bolts the same thread as the 4 main bellhousing bolts(two each side)and using these as studs to slide the box on/off with.
The problem with taking the engine out is that you will need to drain the coolant,adds cost and more potential problems bleeding the system.
