Which Diff units fit the e30 318iS
TamTom
Post Wed Sep 21, 2011 9:40 am
I am trying to get an LSD on my 318is but cant seem to find much info on a swap etc.
The original diff is small type.
i have already purchased a medium or big case diff, mounting points to the chassis are the same but the output flanges to the driveshafts are a different size, they seem to be slightly larger and the bolt holes do not match.
are the diff flanges interchangeable, from small to large case etc?
Tam
TamTom
Post Wed Sep 21, 2011 7:09 pm
anyone
bump
threelander
Post Wed Sep 21, 2011 7:14 pm
hi if small case was fitted why not replace it with small case.i,m sure it is possible to change things ona medium case diff but seems a lot of hassle
Post Wed Sep 21, 2011 7:50 pm
If the diff. you bought came from an E30, and came complete with its output flanges, then it will fit with a slight adjustment in prop length.
TamTom
Post Wed Sep 21, 2011 11:47 pm
prop length is fine, just the output shafts dont match.
they seem to be bigger than the original diff
TamTom
Post Thu Sep 22, 2011 10:16 pm
anyone?
i basically want to fit a diff to my e30 318is which is originally a small case diff.
Post Thu Sep 22, 2011 11:02 pm
Brianmoooore wrote:If the diff. you bought came from an E30, and came complete with its output flanges, then it will fit with a slight adjustment in prop length.
TamTom
Post Fri Sep 23, 2011 9:44 am
the bolt holes are slightly off on the driveshaft to flange. could this have been from another car do you think?
looks exactly the same, only the flanges seem to be different.
Are the large and small case diff flanges the same pcd fitment as in all flanges would bolt up to all driveshafts regardless of year or model etc?
DHFiS
Post Sat Sep 24, 2011 8:14 am
I replaced a 6 bolt diff with an 8 bolt diff on mine and the only adjustment was prop length.
If the flanges are different I guess its not an e30 diff.
Here's a pic of mine
Brian28
Post Sat Sep 24, 2011 8:54 am
Drives should be the same bolt pattern, the output shafts are longer/shorter to compensate for the different widths of the diffs. They will come out if you get a big screwdriver or pry bar behind them, can you swap for the ones from your original diff?
For sale - E30 320i racer project - sold.
