M52 Sumps
bhups
Post Wed Sep 21, 2011 1:43 pm
Hi Guys,
I noticed that the sumps sit pretty low on the m52. Is there someone out there that makes shallow sumps or are there any other options?
Green
Post Wed Sep 21, 2011 2:29 pm
The e28 M5 mounts raise it up a bit, I used 10mm spacers to aid it a bit and its not too bad.
bhups
Post Wed Sep 21, 2011 7:09 pm
Im already running those mounts.
Green
Post Thu Sep 22, 2011 1:15 am
I didn't think this was that bad really
bhups
Post Thu Sep 22, 2011 9:34 am
I dont know if its the way the pictures taken but mine sits a lot lower than that.
e30-EVN
Post Thu Sep 22, 2011 12:57 pm
and dont forget that plastic slopes downward so doesnt make it look that bad on your car...
i also used e28 m5 mounts and mine sits pretty low! before i dropped the first 24v lump in the car had a 60mm drop, when i was rolling m20 lol...... but as soon as i dropped the m50 in and now the 52 i went straight out and purchased a set of gas shocks and 40mm springs!!!
took it up a few mm but stiffened it up.
i may look into a few spacers on the hockey pucks when i pull it out to do the clutch 8)
Post Thu Sep 22, 2011 1:11 pm
Green wrote:Image
Mine looks identical to that and I am using E28 M5 mounts, never had any sump dramas and I live in speed bump central
ajay
Post Thu Sep 22, 2011 10:23 pm
would the size of the wheels your running make a difference to the ground clearance Ie 15" 17" etc?
bhups
Post Thu Sep 22, 2011 10:29 pm
I suppose it would. Im planning on running 17's so that should help.
Post Thu Sep 22, 2011 10:32 pm
Only a small difference unless you are running lower profile tyres than you should.
