Carpet Replacement
Post Wed Sep 21, 2011 9:43 am
Is there a "best" way to do this ?
I have the dash out now but the heater/blower box is all still in-situ.
Is it possible to re-fit the carpet without cutting it and without having to remove the heater ?
Duke137
Post Wed Sep 21, 2011 9:44 am
Yes it is possible
I would take the throttle pedal out if you can.
You will also need a big bag of swear words to push it up to the bulkhead under the heater box....
Post Wed Sep 21, 2011 10:13 am
Throttle pedal still out anyway mate.
Its being cleaned on Friday afternoon and I might have a crack at getting it back in over the weekend - need to get this turd back together now !
asmith88
Post Wed Sep 21, 2011 10:16 am
can be done without taking the dash out or the heater box, but as duke says, takes a lot of pateince going side to side, getting the carpet up the back of the heater,
throttle pedal is handy took off, just get a pick and gently lever the clips at the base, it should slide off,
1990 brilliant red 318 is
