Fitting skirts, without drilling
Jozi
Anyone fit their tec2/SE/iX skirts without using the holes and gromits in the sills? I rather not go drilling holes in the sills if I can get away with bonding them on?
leeparkes
Tigerseal.
- E30 Zone Meets/Events Team
No.
You'll need to drill for the tech2 ones for them to hold as there is a rubber gasket that sits between the sill and the kit.
Jozi
I'm using iX skirts Rav, which I thought fitted on the same as tec2 or SE skirts (but this gasket thing is new to me).
The rubber gasket is to stop moisture getting in behind them?
Not sure on the iX or the SE ones Brendan, as i have never fitted or seen those up close.
I know that the tech ones have a rubber gasket though 100%
Jozi
Don't see anything listed for the iX skirts as with the tec2 ones.
Also going to need to keep the arch flaresstuck to the body and I'm not drilling holes in anyarches! Tiger seal hold them on long enough? Will you still be able to get them of without much bother, never bonded anything with tiger seal (yet)!
No Tigerseal is a onetime solution and won't let go easily
Curr946
cut the tabs of the clips that go into the sills. then tigerseal the clips to the sills
If your wife must learn to drive, don't stand in her way!
Jozi
I might have to look into double side tape (listed anyway for the ix bits on realoem) or something else just incase I get sick of the ix bits.Rav335uk wrote:No Tigerseal is a onetime solution and won't let go easily
Curr946: tigerseal on the flange of the clips, rather than tigerseal the skirts them selves?
adit
there are a few similar threads on this subject Jozi:
http://www.e30zone.net/modules.php?name ... ight=tiger
[quote="bss325i"]
Jozi
Thanks Adit, I'll have a look through the thread and the links in it before fitting. Anymention of using double sided tape in it?
Jozi
Adhesive tape might be the right job from the quick 2 mins searching
Curr946
yes there's 2 bits on the rear that would go into the holes on the sill cut these off then put tiger seal on the flange of the clip stick this to the sill and your side skirts will then clip on as normalJozi wrote:Rav335uk wrote:No Tigerseal is a onetime solution and won't let go easily
BEMER_LAND
Im going using doubled sided gel type tape, prob wont last at all but its worth a shot if not il be cutting the clips and tiger sealing them
Jozi
If tigersealing the clips on means they stay put then it's worth a shot. Any link to the type of tape your talking about Denis?BEMER_LAND wrote:Im going using doubled sided gel type tape, prob wont last at all but its worth a shot if not il be cutting the clips and tiger sealing them
BEMER_LAND
http://cgi.ebay.ie/ws/eBayISAPI.dll?Vie ... _500wt_716
Il let you know how it goes, only testing it out really
baur320
How did the double sided tape work then?
Current E30 325i, E63 630is.
