unstable, wobbly car at higher speeds,
asmith88
Post Wed Sep 07, 2011 4:51 pm
Feels scary at higher speeds,
when cruising at around 70/80 mph, if i give the steering wheel a flick either side it feels like the back end of the car snakes around,
it also feels like it leans and in the wet i cant do 70/80 because it feels like it will let go at any second,
maybe its just me,
recently all the front suspension has been replaced and the rear subframe bushes have been done as well,
anything else i should check?
cheers
1990 brilliant red 318 is
toby
Post Wed Sep 07, 2011 11:05 pm
Check all the nuts are tight in the first instance - on all the new bits.
Tyres OK? Sometimes an edge of a tyre can wear a lot more then you might expect.
Check all of the wheel nuts are tight and that your wheel bearings are ok
(with no wobbles when you move the wheel with the car jacked up).
Then check all the steering nuts are tight.
KimH
Post Thu Sep 08, 2011 12:20 am
Trailing arm bushes?
There is a section of the M5 near me where one lane has visible grooves made by heavy lorries over which my car used to be very skittish - even in a straight line, which was quite disconcerting. I've just replaced both the Beam bushes and trailing arm bushes in one go and my Touring no longer "Tramlines".
Morat
Post Thu Sep 08, 2011 9:25 am
Basic question, but did you get a full tracking/alignment done after all that suspension work? You might find your angles are a bit off....
asmith88
Post Thu Sep 08, 2011 10:04 am
yea, new tyres all round after wheel alignment,
also new bearings at the front but i will check the backs, and nuts, though there is no knocking or noise, car is lovely and quiet
i will also check the trailing arm bushes,
Barx325i
could be a bent trailing arm, if not the bushes as per kim, to me, it sounds like you have rear shock issues by your description, maybe mismatched tires or pressures
asmith88
Post Thu Sep 08, 2011 10:06 am
tyres all same brand and tread levels, pressures are checked usually every fortnight,
shocks seem fine as well, b6's i will check the trailing arms, any way of testing them effectively?
Barx325i
Post Thu Sep 08, 2011 10:17 am
you can try a diy tracking check with some long bits of straight wood / laser level and a tape measure, it's all a bit heath robinson, but it'll give you a fair idea
As Morat suggests get it checked and tracked up by a 4 wheel laser outfit
asmith88
Post Thu Sep 08, 2011 10:19 am
wheel alignment was all done a few weeks ago, but il take it somewhere for a check and see if its right,
Barx325i
Post Thu Sep 08, 2011 10:24 am
the only thing left is shocks / duff/cracked spring or top mounts
Ajsingh
Post Thu Sep 08, 2011 11:55 am
Have u got the print out after the alignment showing what degrees its all sitting at?
E30 Crazy!
asmith88
Post Thu Sep 08, 2011 2:23 pm
no was laser not computer, i was going to go to a guy with a computer but ecp fecked something as usual,
back top mounts are a bit iffy and need replaced, but would that cause poor handling like this?
springs are all dead on, shocks seem fine, just bump tested them
Martinaston
Post Thu Sep 08, 2011 10:53 pm
Bump test means nothing with a good anti roll bar on the back, undo the bottom nut on the shock and give them a push and pull from under the car.
There is NO nucleus.
asmith88
Post Fri Sep 09, 2011 8:01 pm
will do
asmith88
Post Wed Sep 14, 2011 11:18 am
have been having a look, are the trailing arm bushes handy to do? any guides?
how long roughly in labour?
asmith88
Post Tue Sep 20, 2011 12:59 pm
got the car on a ramp today, one garage told me the car was towing in 6 mm, one garage told me it was spot on :?
anyway i took the opportunity to have a look at the back end, couldnt feel any movement in the trailing arms, when i tried to move the subframe bushes there was a slight bit of up and down movement,
heres some pics of them,
i also found this shock, how much of a problem would this cause?
and this on the filler neck? how bad is it?
cheers
bmw9818
Post Tue Sep 20, 2011 5:30 pm
buckled wheels?, my wheels were bent due to the stupid potholes, felt very unstable at speed, the car used to wave around at about 80-90
asmith88
Post Tue Sep 20, 2011 8:43 pm
new tyres and balanced etc,
johnl320
Post Tue Sep 20, 2011 8:59 pm
That shock is fooked!
asmith88
Post Tue Sep 20, 2011 9:01 pm
it is indeed, do you reckin it would cause any of the above problems?
johnl320
Post Tue Sep 20, 2011 9:03 pm
It certainly wont be helping!
Barx325i
Post Wed Sep 21, 2011 10:44 am
asmith88 wrote:it is indeed, do you reckin it would cause any of the above problems?
most def, also if the rear beam bushes are floating on the alloy core, it's all going to result in weirdness
Morat
Post Wed Sep 21, 2011 11:40 am
Those bushes look wrong to me.
Also, getting an alignment/tracking done isn't plain sailing. Finding somewhere you can trust isn't always easy - I've been to places with the full computer gear with printout who have F$$"£D up the E46 rear toe so badly it was criminal. Strangely, they were also a tyre shop....
Try somewhere that doesn't sell tyres.
asmith88
Post Wed Sep 21, 2011 6:04 pm
whats wrong with the bushes? they where done last year by a bmw "specialist" they have sat like that since i had them done and in fact now they are right on the mounting plate, i remember reading somewhere that there should be a 1cm between the bush and the plate,
any more opinions on the bushes because i paid good money to have these done and im fed up with people feckin things up and taking my money,
