no power getting to my fuel pump.
damian666
There isnt any power getting to my fuel pump i have looked at the fuse and there isnt power getting there either. does anyone have any ideas?
Jim320i
- E30 Zone News / COTM Team
Have you checked the relay?
Welcome to the zone too.
Grrrmachine
- E30 Zone Wiki / Team Member
If there's no power to the fuse, that suggests the DME relay isn't activating when you turn on the ignition. While that may be the cause, it's more likely that the Crank Position Sensor has come loose, or its cable has been frayed, which in turn isn't telling the ECU to switch the DME to turn on the fuel pump and injectors.
So check the crank position sensor
No power to the fuel pump when?
Billwill
damian666 wrote:There isnt any power getting to my fuel pump i have looked at the fuse and there isnt power getting there either. does anyone have any ideas?
What model E30 is it?
threelander
check fuel pump relay bill
