Hi
The 320's battery is not charging. Got stranded with a flat bettery and the AA man had a look and got it charging after jump starting it by "feeding it a live" whatever that is (looked like he put his multimeter somewhere under the inlet manifold), he doesnt think its the alternator at fault, but a fuse or loose/damaged wiring.
When it come to electrics, I'm lost
Any tips appreciated.
Thank you
Battery not charging
Billwill
You need to put a voltmeter over the battery while the engine is at idle...you should get about 13.5 volts. If not, check the battery connections are clean and tight, check the main earthing strap that earths the engine to the chassis is clean and tight, check the alternator belt is tight.
There is also, I believe, a "fusable link" that couples the battery to the alternator....this looks like a normal lead but actually has a fusable section inside that will blow if you have a bad short or try charging the battery with the charge terminals connected the wrong way around.
Otherwise you need to have the alternator tested and maybe re-conditioned.
There is no fusible link in the charging circuit of any E30.
Have you charged the battery?
Does the battery light come on with the ignition and go out when the engine is started?
Does the car start normally with a charged battery?
Grrrmachine
- E30 Zone Wiki / Team Member
Electrics aren't hard to understand, but if you want to fix it yourself you'll need a cheapo multimeter than can read volts. Even a 2quid one from the market will do.
When the car is off, set your multimeter to V-20 on the dial, and stick the electrodes on the battery terminals. You should get a reading of around 12.6V. If it's below 12.2, your battery is on its way out.
Then start the car, and let it idle. Measure again, and you should see a reading of between 13.7 and 14.4. That shows the alternator is charging the battery. If it's more than 12.6V but less than 13.7, your alternator isn't charging as much as it should. If it's even lower than 12.6, you're not charging at all and the engine is draining precious battery juice. Turn the engine off and get the battery onto a charger. If you drain the battery too much, you'll kill it.
Now start following cables. From the black battery terminal you should see a big fat cable, connected to the inner wing about six inches away. Tighten the wire at the battery terminal, undo the wire from the other end, and clean it up with a bit of sandpaper. Re-attach.
Now look under the car and look for a similar chunky cable running from the bottom of the engine to the car body. Again, undo it, shine it up with sandpaper, reattach. Now restart the car and remeasure the volts. If it's up to 13.7V, you're good. If it's not, it's time to follow the red wire.
Look at the red terminal of the battery, and you should see a similarly chunky wire heading from there to the starter motor. Again, check it's all tight, and follow the second wire from the starter back to the alternator.
If everythings free of rust and tightly fastened, it should work properly. If it still doesn't, you've got problems either at the alternator or (more likely) the voltage regulator.
retroboyo
I have taken the battery out and started charging it. I could take the terminals off by hand without undoing them, I did say to the AA man that they seemed a bit loose but he didnt tighten them. He did put the voltmeter on the battery whilst at idle and it was 12.25 approximately. He said it was charging at times and then not charging.
I started it ok before I took the battery out and forget to check if the battery light came on sorry. There was no light once it was running though.
Topblag
What are you charging it with - i.e. a small domestic battery charger or something larger and more industrial ?
My cabby battery wouldn't take a charge at all after going totally flat. My domestic charger wouldn't get it going (8amps) and my mates industrial one(20 Amps) got it charged first time. I understand that if a battery is totally flat, you need 15 amp + to get it charging again.
1984 Hartge H35 in Black
2006 Audi S6 V10 in Black 58k
- **BANNED**
I think that you might,just,have found your problem.....retroboyo wrote: I could take the terminals off by hand without undoing them......
Youth is wasted on the young.
retroboyo
thanks you, I hope so
My charger is domestic i'm afraid, I'll see how it does
Once its back in the car I'll do the voltmeter test and tak you for explaining that
Thank you all for your advice, it makes a world of difference, it really does
I have hope now
I have hope now
retroboyo
Well, I put a different battery in there which is ok and swapped the power regulator from the 325 to the 320 which is not charging (not sure if I should do that). The 2 power regulators had about the same amount of copper bush on them, but I swapped them anyway to see. It was hitting 13V when I first testing it but then dropped to 12s. Seems to fluctuate but mainly around 12.8V
I havnt checked the cables yet.
Seems low. Measure the voltage across the battery with the engine running, headlamps on full beam and rear window on.
Take the measurement at idle at at around 2000 RPM.
retroboyo
I will check that, thank you
