Anybody know procedure to remove fuse box or write up- water
clydesdale
I have a water leak, behind the fuse box. I finally tracked it down. The seam is rotted and water runs right in. To patch it right, I need to remove the fuse box and make room.
Grrrmachine
- E30 Zone Wiki / Team Member
I've just done this repair:
http://www.e30zone.net/modules.php?name ... 69#2229069
The fuse box simply unscrews from its mountings. However, you can't actually undo the loom; it's a one-piece component, fuse box included, so you'd have to strip the entire interior to get it out of the car.
Depending on the size of your rust issue, you might be able to pull the fuse box far enough away to attempts a repair, like I have.
sag
iv just recently removed my fuse box its not a bad job but it involes removing the interior complete.The loom runs from the rear lights all the way to the front lights with no breaks in the wires just one complete piece. There are around 7 sub looms which u can leave
if its a permanent repair then ill suggest on removing the loom complete. If its a tempory repair then patch it up,you can move the fuse box slightly.
All in all send some pictures of where the repair work is needed
Cutting a few cable ties behind the glovebox area allows the fusebox to be pulled up a few inches to allow some room to work.
Not ideal, but just about gives access.
clydesdale
I plan on sliding the fuse box over, as much as I can and using fiberglass to patch the infected area. I used fiberglass to patch a 2 inch by 2 inch hole in the arch well and that worked great. The problem is that I did not see that the seam that cracked is right above the patch I made. So, I need to patch more.
But, I can see the crack in the seam from the footwell side. My question is, how does the water get in from the wiper/air vent? Doesn't it mean that the sealer in that channel must be cracked and is allowing water in? Or is it designed to allow water to flow down from there? Could I just stuff fiberglass in from the foot well side of the car and seal it up? I would then clean and fiberglass it from the fuse box side also.
tal
tal
Grrrmachine
If you use fibreglass, you're just buying yourself six months to a year before it all fails and starts leaking again. Plus, you're talking about a structural part of the car here. You really ought to do it properly.
Still, if you want to go ahead, click here...
http://www.e30zone.net/modules.php?name ... 97#2233497
When you say "seam" are you talking about the horizontal seam where the scuttle meets the bulkhead, or the vertical seam where the wheel arch meets the bulkhead? Either way, if you don't cut out the rust and put new metal in, it'll just get worse.
As to your water ingress, water gets in through the wiper vents into the triangular cavity formed by the scuttle sitting on top of the bulkhead. Water is supposed to drain sideways though the triangular hole in the inner wing, but often gets absorbed into the seam sealer there and rusts out from the inside, rotting away three layers of metal in the process. By the time you notice it, it's a serious repair.
clydesdale
Your pictures are a major help. Thank you. I have a problem with the horizontal seam, in about a 2 inch area. The vertical seam appears to be fine.
I don't think my rust issue is as bad as yours. The inner wing had only a small hole. Before I fiberglass, I cut out the rust and grind the area clean. I am going to have to try it, I do not have it in me to take this thing apart that far. I use this as my daily driver beater car. It is no show queen and I just need to stop the leak. I used fiberglass to patch the trunk corners. The previous owner let the tail lights leak enough to put holes in the trunk. The glass has been working great for almost 8 years. The problem I see here is getting the scuttle vents to drain properly.
clydesdale
Grrrrmachine,
I removed the plastic arch well liner and there was no additional rust inside the arch. The side of the inner part of the fender is totally solid. From inside the arch well, it all looks solid. I managed to move the fuse box a little more as well. What I do not quite get yet, is how the scuttle vents drain. I want to make sure I don't seal the drain. Right now, I can only see the hole from the engine compartment, but I realize if I seal the hole there, the vents will still drain into my car.
We are getting a lot of rain here. I sealed it by wrapping the vent in kitchen plastic wrap. It is not stylish, but it cut down 90% of the leak.
So, do I rip these panels apart from the engine compartment?
Grrrmachine
See the triangular hole there? That's the scuttle drain. Shine a light through the scuttle vent, and you'll see it through that hole. This is why a fibreglass repair isn't a good idea; the inside of that needs to be smooth so that the water naturally flows out to the side, and out.
You need to get the wing off and see the condition of it from there. A photo of the problem would really help.
If the hole is only on the cabin side, it's good and bad. The good is that the repair itself isn't so hard; the bad is that the dash will have to come out to fix it, unless you have extremely nimble fingers.
clydesdale
Oh, I will be nimble. I just can't take the car apart. This will have to be the best bandaid I can do. There was a hole in the inner arch, I patched that. But, that lead right into the cabin. I will get a pic soon as I can. It is raining today. Thanks.
clydesdale
When you say wing, is that the same as the front fender sheet metal?
Grrrmachine
Sorry, yes, over here the bit of metal around the wheel is called the wing. The photo of mine is with the wing removed, showing the inner wing structure.
The wing unbolts very easily, doesn't take any special tools.
clydesdale
Ok, removing the wing will let me see where these 3 pieces meet? I saw no rust when I squeezed my head in there to look at what is behind the outer wing.
clydesdale
Ok, here is a pic of the repair in progress. I have removed the spot welds for the fuse box, flipped the bracket down and then peeled back the roof of the scuttle drain. This exposes the huge hole that was raining into my car.
http://rides.webshots.com/photo/2035730 ... 1901YSuxKY
http://rides.webshots.com/photo/2867823 ... 1901wmITbv
Grrrmachine
Yep, exactly the same rust I had. You could slap a load of fibreglass over it if you wanted to, but then make sure you brush over it with seam sealer and then spray that with a cheap acrylic paint from an aerosol. That'll last for a year or two until the car either rots out in other places, or you learn to weld.
For brushable seam sealer, thin it down and apply with a brush with the bristles cut in half. That'll make it a bit easier to deal with. But try not to make your repair too much of a "mound", or the water won't be able to flow away from it.
However, the other crack shows that the inner wing is separating from the bulkhead. That's really not safe, and you're at the point where you ought to fix the car properly, or stop driving it.
clydesdale
I painted it today with an epoxy primer and I made a fiberglass patch. Next weekend I will trim the patch and lay it into place. I will then glass that into place. I did not want to just make the patch on the car, as it will likely drip where I don't want it yet.
My brother knows how to weld, but we just don't feel like doing it for this at this time. I would need to remove the brake booster and the foot pedals inside. A LOT MORE WORK would be needed to make this a good weld patch. I just need to stop the water. I don't see any structural issue at this time.
If I keep the car long enough, where the motor comes out or if I need to remove the brake booster, I will grind out my patch and do a better job with a welder.
Grrrmachine
It's a lot easier if you just get that wing off, you shouldn't need to touch the brake booster at all to do that repair, unless your rust has spread all the way across to the heater matrix for the cabin.
