Intermittent electrics issue.
Ranchero
Post Fri Sep 16, 2011 6:45 pm
With the ignition key in second position the electric windows work fine. As soon as the engine is turned over they stop working although they occasionally randomly start working again. This is also effecting the heater blower switch.
Any thoughts?
fixedwheelnut
Post Fri Sep 16, 2011 8:46 pm
Ignition switch? check the voltage output from the switch
Post Sat Sep 17, 2011 12:38 am
Power for the windows and heater fan doesn't pass through the ignition switch. Power for these items (and others) is fed by relays directly from a thick red wire from the battery.
The windows and fan are supposed, by design, to stop working as soon as the starter motor is engaged, but should come back to life when the starter switch is released.
Your problem centres around relays K5 and K7, or more likely, since both are involved, the control circuit for them. This is a black/green wire that goes from the fusebox to the smallest terminal on the starter motor.
Ranchero
Post Sun Sep 18, 2011 5:55 pm
yep, the 8mm nut had worked itself loose from the top terminal of the starter :o: . Must get a torque wrench before the car falls apart.
Nut replaced and windows now working as they should. Thanks for the heads-up Brian :thumb: .
