need to ID a head for someone. It has 1 264 200 on the casting (where the 2.5's have 1 705 885). I'm thinking 323i or early 320i maybe e21???
Cheers in advance
What M20 is this head off?
johnt0709
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
Cheers. it's worhtless then!.............
Andyboy
- Alpina Colada
If it has only four cam journals with oil holes, it's 525e. If all seven have oil holes it's an E21 320 or 323i. Either way, if it's in good nick it's worth chucking up in the attic. Not big, doesn't weigh much. Wortless as scrap because it's mixed (alloy with steel).
These days, don't throw ANY stuff like this away. One day, some desperate sod will give you 200 quid for it, when there are none left due to them all being thrown away.......
- **BANNED**
200 castings with four drilled journals can be converted to seven drilled journals...but you will also need to open up the ports as well!
As Andy says,hang on to it,I have one in store as well....journals already drilled out(that's easy)it's the porting that worries me.
Youth is wasted on the young.
VW-will
I have a head with 2.5 and underneath 2.7 what does this mean?
- **BANNED**
Standard 885 casting fitted to 325i and early E34 525i.VW-will wrote:I have a head with 2.5 and underneath 2.7 what does this mean?
Cheers guys.
Andyboy
- Alpina Colada
Eta and E21 ports are the same..........daimlerman wrote:200 castings with four drilled journals can be converted to seven drilled journals...but you will also need to open up the ports as well!
