one thing i am confused about is the trailing arm bushes which they said come with "two eccentric" and "two normal" bushes..
so where does the eccentric one fit and where does the normal one fit?
Thanx in advance
dont worry Rav you'll see plenty when i get the pics up of my rear end overhaul! what a few days it has been and it aint over yet!Rav335uk wrote:Watching.
I was thinking the same thing about the identical bushes hence why i asked them if they were sure about having two of eachBrianmoooore wrote:AFAIK, all the bushes you normally fit are identical. The eccentric ones from BMW are for camber/toe correction where things have been bent out of spec.
If you use the eccentric ones, the suspension angles have to be measured using the old concentric bushes, and then this data used to calculate what rotational angle to install the eccentrics at.
hmm sounds interestingBrianmoooore wrote:You can't adjust these eccentric bushes once they are fitted. The measurements and calculations have to be done before work is started.
A much better option is to modify the rear beam with 5 series eccentric bolts, and welded on tabs, like those that DanThe sells. This gives fully and independently adjustable toe and camber for each side.
oh rightBrianmoooore wrote:Modified beam uses the standard concentric bushes.
seems that way from what im reading/hearing, just dont understand why BMW out of all people said i need two of eachJozi wrote:Concentric + modified rear beam is the way to go. From what I've read the eccentric ones are not easy to setup.
cheers mate..the way i thought of this overhaul was that im prob only ever going to do it once so id get it all from BMWJozi wrote:Prob because both eccentric and concentric are listed with the same item no (different part no's) and both have a quantity of 2 listed. They probably don't deal with E30's much and can only go with what it says on their screen. A tip for when looking for bushes again, try get Lemforder they make them for BMW (apparently) so you get the same quality but at a lower price
I would imagine reading how to fit eccentric trailing arm bushes will confuse you more, than just physically doing it..Jozi wrote:Concentric + modified rear beam is the way to go. From what I've read the eccentric ones are not easy to setup.
yea im looking to do that in the near future...well when i can save some money again lolBarx325i wrote:I would imagine reading how to fit eccentric trailing arm bushes will confuse you more, than just physically doing it..Jozi wrote:Concentric + modified rear beam is the way to go. From what I've read the eccentric ones are not easy to setup.
But in either case, Dans' adjustable setup is king
I'll second thatBarx325i wrote: But in either case, Dans' adjustable setup is king
