M20 engine loom with CAT question
n1tr0_9
Post Thu Sep 15, 2011 6:08 pm
I have an engine and engine loom from a late 325i fitted with a CAT and Lambda. If i want to fit the engine loom to another m20 that doesnt have a CAT and Lambda, do i just remove the Lambda relay next to the DME and Fuel pump relay, and unplug the Lambda, or will this confuse the ECU. Will i need another ECU?
Post Thu Sep 15, 2011 6:44 pm
No changes needed with the M20 - the ECU will automatically substitute a default value.. M40/42 has a wire that needs connecting/disconnecting.
n1tr0_9
Post Thu Sep 15, 2011 6:49 pm
Thanks Brian!
