Speedo KPH to MPH
Gwynleym10
Post Tue Nov 08, 2005 11:46 am
The speedometer and odometer and trip are all in KPH on my car (316i m40). There are no MPH markings what so ever!
I don't mind this all that much, as I have a good idea about what speed is what. However my girlfriend doesn't like it (been a new driver) and get a bit paranoid around speed camera's etc.
I don't want to change the clock over completely as its a pretty low mileage (64 000) so i don't want to loose that.
Can you just get a face for the clock which will have both? Are m3 clocks (I assume they have both???) interchangable?
I seam to rember reading that the needles can be easily damaged is this correct?
The car has obviously passed all its MOT's like it is, I thought that you had to have the speedo in MPH to pass the MOT, or am i wrong?
London 2 Cape Town
www.Overlandinthesun.com
kam-325i
Post Tue Nov 08, 2005 11:48 am
I allways thought that aswell.
Andy_magic
Post Tue Nov 08, 2005 11:50 am
I'm pretty sure you can just change the face over, the odometer will read incorrectly still.
A vehicle needs to have an MPH speedo in this country to pass an SVA test. Like when you register an import that has not passed the various regs for this country.
I think as long as your carefull with the needle it should be fine.
boomer
Post Tue Nov 08, 2005 11:57 am
ffs
Divide by 8
Multiply by 5
It's called mental arithmetic
If you can drive a car then this should be easy.
Andy_magic
Post Tue Nov 08, 2005 12:12 pm
top post boomer.
Wouldn't it be easier to divide by 1.6
Simon
Post Tue Nov 08, 2005 12:23 pm
My M3 still has the KPH clocks, it doesn't have both, you are thinking of MPH clocks, as they have the KPH in smaller writing.
Mine's been fine for MOT's it's been in the country since 1997 like it, and I've just learnt what's what!
boomer
Post Tue Nov 08, 2005 12:24 pm
even simpler
work out the matching mph/kph readings
use tippex/tape to mark relevant lines on speedo covering
Memorise readings
remove lines
Alternatively a quick multiplication by 0.625 should suffice
Gwynleym10
Post Tue Nov 08, 2005 3:39 pm
Oh well not that bothered, what i really wanted was KPH main (so my odometer would be correct) will MPH in small letters around.
I can cope with the maths, I know where the needle should be.
just one of those things to get used to!
London 2 Cape Town
