e46 steering rack, uj question. NOW URGENT (see latest post)
tomislav
As far as i know, to connect the steering column i have to use the e46 lower half and e30 top half of the column uj.
But these aren't bolted together are they, as standard they seem to be rivets.
Do i assume then that i have to drill these out, swap the bits about and then bolt after?
Also, leae the rubber bit in or out?
tomislav
bttt
e301988325i
Mine uses all e30 linkage, guilbo removed and two halves bolted together
I said:
e30topless said:
lock the wife in there
tomislav
Yet again you are a star, you've answered all my questions about steering racks so far lol.
Thanks.
Actually, while i think about it, oil coolers for the PAS.
At which point in the pipework do you plump them in?
I'm thinking:-
Reservior to pump
pump to cooler
cooler to rack
rack pipes as normal from there
Any ideas?
Ta e301988325i
Thanks.
I'm thinking:-
Reservior to pump
pump to cooler
cooler to rack
Any ideas?
Ta e301988325i
Coolers are always in the return to the reservoir
tomislav
oh, so the oil goes thro the rack then tro a cooler back to the pump
No, fluid leaves the res and feeds the pump, high pressure from the pump to the rack, low pressure from the pump back to the reservoir (via a cooler if you want one)
Motorhole
Sorry to hijack your thread Tomislav - but will the all-E30 linkage with guibo removed work with an M52 and M52 manifolds? Also if using an E46 rack:
1) are the spacers for the rack on the subframe still required? If so, still 15mm?
2) How necessary is the cooler?
tomislav
1 yes you need spacers, in my case a 9mm thick 19mm nut one side and 2 washers the other!
2 i'm not taking any chances. some people say its not needed, others do. i track mine and do drifting too so i'm playing it safe, gonna use the auto gearbox radiator to do mine as its already there
The actual height difference between the rack mountings is 14mm. You should fit the spacers above the rack
charlE30
I've run mine for the past 3 maybe more years without a cooler without any issues whatsoever but mine doesn't see a track, if it did I would want to fit one. I'm liking your idea about using the auto rad, we will need some details when you do ittomislav wrote: i'm not taking any chances. some people say its not needed, others do. i track mine and do drifting too so i'm playing it safe, gonna use the auto gearbox radiator to do mine as its already there
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
e301988325i
Fittings would be hard work for the auto radiator.
No idea about 24valver fitment.
As charlE30 said he is fine without a cooler, Chr1s1990 and I NEED a cooler.
As DanThe said about cooler position in the circuit.
I used a cooler from an E46, plumb it in so it feeds fluid into the bottom of the cooler and out of the top.
I said:
What made you fit a cooler out of interest?
e301988325i
Steering nearly seized around the nurburgring, it was like dry steering a quick rack on wide tyres! The fluid was burnt and black, took three flushes to fix it.
I said:
tomislav
It won't be that hard to use the auto rad, just cut hoses and add lengths of extra pipe.
When i did the auto maunel conversion i left approx 12 inches of the rubber hose for the auto box supply down the side of the rad because i didn't want to risk undoing them out of the rad.
I think thiswill now benifit me quite a lot to make it easier, no fitting needed as such
tomislav
Using the auto rad as the cooler is now the least of my worries!
Got subframe, rack, lower arms etc back together then went to fit it all.
Some issues (ps i leave for the nurburgring on 17th June!).
1. I have a hottuning manifold fitted, without the steering uj fitted its about 5mm away, cutting of manifold needed is my guess???
2. Should i fit the manifold in the front most holes or rear most holes on the subframe?
3. What sort of pressure does the high pressure side of the power steering work at roughly? Only wondering because if i use cut pipes with rubber power steering hose held with jubilee clips for instance, will they hold?!?!?
Input please as time is against me a bit.
Thanks in advance
Thanks in advance
To keep the standard steering angles use the rear holes, this is where the E30 PAS racks are mounted, manual racks are fitted to the front holes.
Jubilee clips will soon start leaking on the pressure side
I can supply a custom pipe for the pressure side depending on engine, pm me
e301988325i
I beleive it's 1000 PSI, whatever, jubilee clips and rubber pipe on the high pressure side will never work. 5mm clearance counds fine, I took the corners of the square bits to add another couple of mm clearance, as you're off to the ring, which is a long wa from home, a set of uprated engine mounts will secure the engine much better if yours are looking tired.
Mk2 RS2000 excort code F7P IIRC mounts from www.burtonpower.co.uk are the best cost option IMHO.
Also worth uprating the gearbox mounts to E21 items whilst you're at it.
I said:
tomislav
to e301988325i, the 5mm clearance is WITHOUT the steering knuckle fitted, i cant get the knuckle on at the moment!!!
Are the escort ones a bolt on fit then?
To Danthe, you will have a PM later but i'm doing this at work and have to be a bit careful lol
e301988325i
engine mounts are a direct swap, gearbox mounts require a little fettlng as the threads are a size up.
Of course that's without the knuckle, as only the btb3 manifold clears the later quick racks. btb offer a revised front or rear section (I can't remember) for btb2 owners to make the run the same as btb3, but they don't modify the original it's a whole new section. I heard they had stock of btb3's recently for £600 which is ultimately the best solution with a nice 10bhp+ power upgrade for the ring as well.
I said:
E21 gearbox mounts are now £62 with discount
I found an alternative here - http://www.e30zone.net/modules.php?name ... c&t=196392
e301988325i
It looks like burton power could again be the supplier for these if E21 mounts are unvailable:
FP292 for engine mounts and FP291 for gearbox, best to ring them as 'm only going by scale on the gearbox mount.
http://www.burtonpower.com/catalogsearc ... 80&q=mount
I said:
tomislav
Cack, i should have asked about the manifold clearance before i started this! What a c**t.
Looks like some exhaust 'modifying' is gonna have to happen.
I cant really justify 600 large for that exhaust, no matter how good.
I'll keep this thread updated as to how i get on, and thanks again to people for the info, its well needed!!!
tomislav
Right, Danthe, you have a pm.
As for the progress, i took the manifold in question off last night and attacked it with thegrinder of angles!!!
I've cut it to the point where the uj fits but now have the task of modifying it to blank the hole i've cut!
This is were a friend of a friend called 'taliban' (don't ask, its a nick name even tho he isn't even slightly middle eastern) comes in, blacksmith by trade, very VERY good quality work.
I dropped the manifold off today, he said give him a week so we'll c what happens. It won't be pretty but it will be functional.
Depending on how this works out then if other people are interested in having this mod done i know a man who can!!!
Its not what you know...
tomislav
Right, manifold now fits fine, steering connected, off to a PAS specialist tonught to get hoses made up.
Can someone please post asap if the following is right or wron?
Reserviour to pump
Pump to rack
Rack to oil cooler
cooler to reserviour
Reserviour to pump
Pump to rack
Rack to oil cooler
e301988325i
correct, the only high pressure line is betweeen the pump and rack.
I said:
tomislav
UPDATE!
Had the power steering pipes fabricated in front of my very eyes on friday evening after work.
A place in Maidstone, Kent, called H.A.H.A's (Hydralic Adapters and Hose Applications). A guy called Nick there said he could sort it and did using my old ends with new rubber hoses.
The pipes now run to the front of the car, along under the rad and up the other side, its all tidy and works a treat.
£140 all in!!!! Touch.
He has also said that if people in the Kent area want this mod done and pipes made up then he'd be happy to do it again although it will be £160, mine was a trial run as such.
Get some pics up
tomislav
I haven't got a photobucket account or anything to do it but i'll sort it when ican.
I'll be honest danthe, they aren't as class as the ones you offered me but i needed them local and fast.
They do the trick, don't leak and are quite tidy so i'm happy
I was planning to look into making a kit to use a later cooler as they look the part, quick release connections and can be mounted in front of the rad at the bottom,
One here -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 500wt_1156
One here -
tomislav
Hey people, anotherb update and answers needed.
All seems to be ok, except for the fact i think the steeing uj is under too much pressure.
I've moved things about a bit and made it better but i've lost a certain amount of my self-centreing.
This is a bit of a problem when i'm drifting cos now the steering doesn't spin back the other way!!!!
I want to get the uj shortened just by a few mm, mayber this will help.
Any input greatfully recieved.
e301988325i
Rack mounted in the lowest position, two halves bolted together, for extra centring use offset front bushes.
I said:
tomislav
I use a company near me called rally design and they specialise in mk 1 and 2 escort bits. I assume then that i could just get their mk2 mounts instead yeah?e301988325i wrote:It looks like burton power could again be the supplier for these if E21 mounts are unvailable:
Gonna go down there 2moro but any opinion is helpful reall.
Also, off to the ring again on sept 16th
tomislav
Right, another update.
Went to rally design and went all out and bought some vibratechnics mk2 escort engine mounts to the tune of 103quid!!!
I'm out at the ring this weekend but so far i've not had any steering issues (just sounds like my diff is about to jump out!!!).
There's one corner in particular on the ring that gives issues so when i get back i'll let you know how it is.
kman82
wow £103!! I've just ordered some from burton power for £22. Do you think theres a massive difference between then?
