Looking at over hauling all the suspension on my e30. Basically all the rubbers that wear out.
Not looking to lower the car or put any springs in it.
What are the usual culprits that need changing?
Suspension overhaul bushes
m_jermyn
Front :
Top mounts
Droplinks
ARB Bushes
Rear
Top Mounts
ARB Droplinks
ARB Bushes
Beam Bushes
Trailing Arm Bushes
Top mounts
Droplinks
ARB Bushes
Rear
Top Mounts
ARB Droplinks
ARB Bushes
Beam Bushes
Trailing Arm Bushes
- **BANNED**
Rob's forgotten the front wishbone bushes and the rear axle carrier bushes....
Youth is wasted on the young.
Rear axle carrier - Beam bushesdaimlerman wrote:Rob's forgotten the front wishbone bushes and the rear axle carrier bushes....
Yes forgot the wishbone/lollipop bushes - fit M3 Eccentrics
- **BANNED**
And the diff mounting bush!
Bearing in mind that the rear axle carrier and the diff(Z3M bush here!)are rubber,the trailing arms can be better located with polybushes,with no fear of road noise being transmitted into the cabin.
Grrrmachine
- E30 Zone Wiki / Team Member
There is a list on the zone wiki, but I've heard some of the part numbers are out of date. Still, it's worth checking:
http://www.e30zone.net/e30zonewiki/inde ... Renovation
For example, the E46 top mounts are now part number 33526779670, according to RealOEM.
m_jermyn
What about getting one of them poly bush kits?
Grrrmachine
Mixed opinions. I've not heard that it improves performance in any way, it's just longer lasting compared to rubber, at the expense of increased road noise.
- **BANNED**
Polybushes transmit noise into the cabin,and are far to stiff in some places for a road car.m_jermyn wrote:What about getting one of them poly bush kits?
I would never,ever,fit polybushes to the rear axle carrier because they change the way the car responds when cornering,um,briskly...
I use poly for the front wishbones(M3 pattern)front ARB mount,rear trailing arms and the rear ARB mounts.I have used a poly diff mount bush,but currently both cars are running rubber here.
The noise transmitted into the car from the front wishbone bushes is noticable,my dad(an E46 owner)commented that he could hear,but not feel,the suspension working.
Against that,the polybushes retain the 'new bush' feel seemingly for ever.
I ran two E30's side by side with one on standard pattern concentric front bushes and one with M3 pattern eccentric bushes(both poly)Even my wife,who would sooner walk than get the car out,commented that the eccentric bushed car 'felt nicer in corners'.
m_jermyn
Had a look at the Wiki page and that makes things a whole lot easier to understand.
Pretty much order everything off there?
Seems the only thing I have to consider is the thickness or my ARBs
Grrrmachine
This might help, by the way. The Lemforder part numbers for various bits:
E46 Top Mounts LMI25853
Trailing Arm Bushes LMI10644
Rear Beam bush LMI10639
ARB drop links LMI10670
If I order those four lemforder parts from my local motor factor rather then BMW, it's half the price, even though the BMW original parts are Lemforders. No idea why the price is so different though.
And my touring ARB is 13.5mm.
