Checked he bulbs which are fine, the connection to the bulb circuit board things are fine too.
As it's both sides, could it be a problem with the switch?
Rear fog lights not working
cee
1990 Sterlingsilber 318iS - 146 bhp / 192 Nm
You realise that the headlamps or front fog lights have to be on?
Does the tell tale in the cluster light?
Check fuse 15.
Check fuse 15.
cee
Yep, still not working, all fuses are brand new.
cee
Oh sorry, no, only the one for the front fogs comes on.
In that case, power isn't even leaving the dashboard area.
Pull out the switch and unplug it. Use a short piece of wire to link together the yellow/black wire and the grey/purple wires in the socket.
Does this make the foglights come on with the headlights and ignition on?
cee
Nada. Can't be the switch then... I'm guessing I'll have to trace the cables
unless you have any other ideas?
I have plenty of other ideas, and will have no trouble in sorting this IF you give full and accurate results to the tests I suggest, and the tests are performed accurately.
I don't jump in suggesting you change this or that as this often leads to one fault being cured and a couple of others introduced - I perform tests, and then, based on the results of those tests, perform further tests until the fault is pinned down precisely.
Are relays K4 and K8 (the two closest to the bulkhead) both black in colour?
I'm not at all convinced that fuse 15 is good, so swap it with another one.
If still no go, connect a piece of wire directly to the battery + terminal, and the other end to the grey/purple at the switch socket. Watch out for large sparks when you connect it, since you are connecting an unfused wire straight from the battery to a suspect circuit. If all is well, the tell tale (and both rear foglights) will light.
cee
Fuses are brand new but I will try a different one. I used an amp meter which showed the front connection as 12v and the rear returned negative numbers and zeroes.
I'll dig out some wire and head over to the car in a bit & run through those steps.
cee
Fixed! Turned out the fuse box diagram I used was wrong - it told me fuse 15 was unused!
cee
While on this topic, I also have listed that 25 and 26 are unused, is this true?
26 is used for the rear wash/wipe on Tourings.
25 isn't used on any model as far as I can remember, but is permanent 12 volts live, so can be used for any extras you might fit to your car.
I use it for the power feed to LPG systems when I fit them.
cee
Great. Thanks a lot for all your help
