Anyone come across this before..? (Trailing arm bolt)
Post Fri Sep 09, 2011 11:11 pm
Got a Trailing arm bolt stuck in the bush 'sleeve', by the beam mount..
Undone the nut, gone to punch it out and the damn thing is jammed. Hard. Made sure the other leg was still able to be bolted up, but still no joy. If you turn the bolt, it ends up turning the bush in the arm!
Soaked it in WD-40, twatted it with a big hammer and a punch. Nothing.
Errr... Any ideas? Or am I going to need to rebuild a trailing arm...?
Can't use fire, or can't see it necessarily helping... Would rather sacrifice the arm than the M3 beam.
**BANNED**
Post Sat Sep 10, 2011 9:06 am
Only thing that I can suggest is heat,I assume that the beam/trailing arm is mounted in the car?
Youth is wasted on the young.
Post Sat Sep 10, 2011 9:59 am
Nope.. Sat on the garage floor. Heat will just melt the bush I imagine, making it harder to get the collar off?
**BANNED**
Post Sat Sep 10, 2011 10:16 am
That's how I dealt with them!
OK,my bolts were not rusted in like yours,but burning the rubber out will enable the bolt/bush to come out.
The rubber burns off in a very satisfying way,the beam is left un-damaged.
Post Sat Sep 10, 2011 10:18 am
If it's on the garage floor, cut the bolt off either side, as close to the bracket as possible, centre punch the resulting disc of fresh steel either side, then drill in a couple of mm from each side with ever increasing sizes of drill bits, until you can pull the arm free.
