I'm having trouble with my lights inside the car.
Basically I have no dash lights (except the warning lights), no heater control lights and basically any lights that can be dimmed by the headlight switch.
I thought it could be the headlight switch, but I've changed that and have ground the earth from the cigarette lighter, but still nothing!
Any ideas chaps?
Dash lights not working
Ranchero
Have you checked fuse 23?
jonnie
Yes of course, I'm not that bad!! ;)
You seem to have covered all the normal bases, so time to try something else.
Connect a piece of wire to the battery + terminal, and touch the other end of the wire onto the grey/red wire on on of the easily reached bulbs, such as the rear ashtray light.
Do the bulbs light?
Do the bulbs light?
jonnie
Thanks Brian, I'll try and that next and report back.
jonnie
Brian, tried that, nothing.
Now earth the brown/white wire as well.
