These seem to have been attached to the arch of my car via some sort of plastic rivets which appears to be OEM
Unfortunately I couldnt see how to remove them without busting them and ended up just knocking them out.
Any issues with using normal nuts and bolts for reassembly ( well waxoyled of course ) ?
Facelift SE Skirt fitting
Dont bodge it! Get some replacements, number 11 here - http://www.realoem.com/bmw/showparts.do ... g=51&fg=20
There are a few different types on ebay but you would need to measure the hole, I imagine its about 6mm - http://www.ebay.co.uk/sch/i.html?_from= ... Categories
Those Ebay ones with a screw-head will do for me - I want to be able to remove them for future waxoyl sessions
The original plastic rivets in question are of the expanding type, where a small parallel sided plastic pin is pushed into a hole in the centre until it sits flush with the head. A series of similar, but larger rivets are used to secure the plastic trim across the rear of the boot opening.
These rivets are easy to remove by using a parallel punch to push the plastic pin in further, until it drops out of the other side, but then you have to find and gather up all the pins for reuse, which isn't always possible if they've been pushed through into a box section.
In the case of the rivets referred to in the OP, the pins can be replaced by small, self tapping, parallel sided, stainless steel screws. The same applies to the various similar rivets around BMWs which are fitted with plastic locking screws as standard.
