Misfire on M40 318i, Please Help..FIXED!!!!
Jem
Post Wed Nov 02, 2005 9:44 pm
I'm still trying to get to the bottom of the misfire on my 318i
I've so far changed:
Sparkplugs
Plug Leads
Fuel Filter
Distributor Cap (their not cheap :eek: )
Rotor Arm
The airfilter is nice and clean.
I have cleaned with carb cleaner:
AFM
Throttle body (didn't take it of, just sprayed into the body with the throttle closed and open)
Idle Control Valve
I've also used some fancy Redex stuff to clean the fuel system/injectors. It's run through the whole tank with the Redex (been to Swindon and back today), and I've refilled it with BP Ultimate).
It's slightly better, but still a LONG way from running smooth
I've pulled the plug leads off one by one with the engine running, and they all cause the engine to run rougher.
I've had the cam cover off, and the cam looks in good condition.
I've done a compression test:
1 = 161 psi
2 = 165 psi
3 = 165 psi
4 = 165 psi
I'm running out of ideas. What would you check/change next?
I've just checked the new plugs 'they have done 300 miles since fitted) and they are a nice light brown colour.
Please help :cry: :cry: :cry:
Post Wed Nov 02, 2005 11:06 pm
Misfire when? At idle? Under load? High revs?
Jem
Post Wed Nov 02, 2005 11:08 pm
Brianmoooore wrote:Misfire when? At idle? Under load? High revs?
Sorry, it's at idle. Seems fine under load, and has plenty of power, but the mpg is in the high 20's on a long run.
I've also checked the hose from the AFM to the throttle body, and there's no splits in it.
Post Wed Nov 02, 2005 11:11 pm
Air leak on the induction side is first thing to thoroughly check. This includes the crankcase breathing system.
Jem
Post Wed Nov 02, 2005 11:13 pm
Brianmoooore wrote:Air leak on the induction side is first thing to thoroughly check. This includes the crankcase breathing system.
Would that account for the poor fuel consumption?
gazza
Post Wed Nov 02, 2005 11:25 pm
i had the same trouble i tried everything on my m40 ...then i cahanged the cam/rockers and it all went away ...as did my noisy top end ....i thought that if the cam was badly worn it would affect the valves opening and closing properly ....anyway no more missfires,i did the same as you it cost me for leads dizzy rotorarm still did not go away ...good luck
Jem
Post Wed Nov 02, 2005 11:42 pm
The camshaft looks to be in good condition. Cant clearly see about the rocker arms or the hydraulic followers, but to change them gets pricy.
Jem
Post Thu Nov 03, 2005 9:42 am
I'm starting to think it is the cam/valve gear, as it is quite tappy from the head. Would I need to change the hydraulic followers as well, or would changing the cam and rockers surfice?
Simon
Post Thu Nov 03, 2005 10:04 am
Try changing the blue temp sensor too, this can cause lots of fuelling problems.
Jem
Post Thu Nov 03, 2005 10:24 am
Simon wrote:Try changing the blue temp sensor too, this can cause lots of fuelling problems.
It's interesting you say that, as I have noticed it's nice and smooth when started from stone cold for about 3 mins, then starts to get rough.
Simon
Post Thu Nov 03, 2005 10:51 am
Give it a go, it doesn't cost much either, I can't quite remember much bout the M40, but I'm pretty sure it's under the inlet manifold somewhere.
The blue sensor is for the ECU, and any probs can cause all sorts of running probs.
Jem
Post Thu Nov 03, 2005 1:21 pm
I've just ordered one from my local BMW dealer, as they didnt have one in stock. Should be here on Saturday.
Jem
Post Thu Nov 03, 2005 3:37 pm
Another little update:
I've just taken the top half of the inlet manifold off, and checked all the pipes etc for cracks or anything that could cause a leak, can see anything amiss. I have taken the throttle body off the manifold, and given is a good clean with carb cleaner. Now looks all shiny 8) I did find one thing wrong though, the TPS wasnt clicking when the throttle was opened. I've adjusted it so it now clicks as son as the throttle is opened. I'm going to leave the manifold off till I've changed the temp sender, but I'm going to change two gaskets for the manifold and the one for the throttle body too.
jonbuoy
Post Thu Nov 03, 2005 3:58 pm
I thought this sensor was just for the gauge on the clusters? As the M40 has'nt got an Air Temperature sensor.
And the blue plug sensor goes into the block on the M40, not directly under the Inlet Manifold.
Simon
Post Thu Nov 03, 2005 3:59 pm
Jem wrote:Another little update:
All the above should help in eliminating any possible air leaks, also check the intake pipe that goes to the throttle body, iirc too there's a small pipe with a block on the end somewhere on the throttle body on an M40, these tend to split and cause air leaks.
Good thing you've adjusted the TPS, it should click just as you open the throttle to come off idle.
Simon
Post Thu Nov 03, 2005 4:01 pm
It's not an air temp sensor, it senses engine temp, and adjusts fuelling accordingly. M40 has both blue for ECU and brown for temp guage.
jonbuoy
Post Thu Nov 03, 2005 4:04 pm
Nice one mate :D
Just gonna pop down the road :P
Jem
Post Thu Nov 03, 2005 4:48 pm
Just popped a multimeter on the TPS, and it's working nicely dectecting both idle and WOT
jd05
Post Thu Nov 03, 2005 8:07 pm
I have just sorted out out a similar problem with my 318i M40.
It had a misfire at idle, and an intermittent (quite violent) misfire under load.
Like you I changed plugs, leads, distributor cap, rotor arm, checked all the hoses for air leaks etc but it was still the same.
I booked it in for a crypton tune and they said it was the mixture on the AFM, which they adjusted and said it was OK. It was for a day, then it returned.
The car then went to a BMW specialist who then checked the fuel pressure, fuel pump and checked that there was no water in the fuel. He also said that the wrong plugs were fitted and that these engines run better on Bosch plugs. After this the car was still the same. As the main fault was intermittent, it was hard to track down.
I was advised to check the injectors and ECU.
I had the injectors ultrasonically cleaned and refurbed but the fault was still there.
By now I had gone past being frustrated and was nearly suicidal, so as a last resort I bought a 318i for spares which did not have the problem and started swapping bits!
Until I did this, I did not realise that there was actually two faults with the car.
The first fault - a hesitation under quick acceleration (even just blipping the throttle quickly) was a combination of the AFM and ICV. At its worst, the car would actually backfire!
The second fault which is similar to yours only happened when the car had been running for a few minutes. I changed the ECU, coil etc but it would not go. It only went when I changed the engine wiring loom.
This is not a major job and took about 1.5 hours.
Sorry for the long post but I wanted you to know the background of how I got to the bottom of this fault.
I hope this is of some use to you
Justin
Jem
Post Thu Nov 03, 2005 8:16 pm
Thanks Justin, it's worth bearing in mind. I'm going to see what difference the temp sender makes before doing anything else, but it wont be too hard to change the engine loom.
gcorky
Boost Junkie
Post Fri Nov 04, 2005 12:37 pm
got a m40 cam,bought new-fitted to 1992 1.8 head -done 0 miles
reasonable offers invited.
bilstein febi from motormec.
Jem
Post Sat Nov 05, 2005 2:09 pm
Well I fitted the new blue temp sensor this morning, and it's running alot smoother :D Still not perfect, but I'm pretty sure thats being caused by the cam/rockers.
BIG THANKS for all the help guys!!! :thumb: :cheers:
Jem
Post Sat Nov 05, 2005 5:13 pm
Umm, seems I was a little premature with my last post. Just been to pick my wife up from work and it's just as lumpy as before :cry: Does seem more intermittent now, it will be fairly smooth sitting at one set of lights, and lumpy as hell at the next. Once on the move it seems pretty smooth though. :cursin: :cheese:
E30Mark
Post Sat Nov 05, 2005 5:23 pm
Have you run it low on fuel recently? if so the fuel pump could be on the way out....
PM for details
Jem
Post Sat Nov 05, 2005 5:25 pm
I'm not sure it's the fuel pump, as it's got plenty of power if you boot it.
E30Mark
Post Sat Nov 05, 2005 5:48 pm
Have you tried having the fault codes read?
PM for details
Jem
Post Sat Nov 05, 2005 5:55 pm
E30Mark wrote:Have you tried having the fault codes read?
No, is that something that can be done yourself or is it a dealer/specialist only job?
E30Mark
Post Sat Nov 05, 2005 6:46 pm
Specialist job, you need a fault code reader, i have a basic one. if your near Dorset pop in!
PM for details
Jem
Post Sat Nov 05, 2005 8:09 pm
Thanks for the offer, unfortunatly I'm in Cambridgeshire.
Jem
Post Mon Nov 07, 2005 1:34 pm
I dont know if anyone is still reading this, but if you are :wave:
I took the car down to a local mot/test/service place today, and had the fault codes read.................nothing there.
He did also but the car on an exhaust gas analyzer and found the mixture was very weak. He tried to adjust it with the screw on the AFM but couldnt. He did say he thought he could hear an air leak though. I've just got home and sprayed carb cleaner on all the joints for vacuum pipes and the inlet manifold, and there is deffinatly a leak there somewhere, so the whole inlet manifold is coming off this afternoon to have new gaskets fitted, and all the pipes checked for splits etc :twisted:
jonbuoy
Post Mon Nov 07, 2005 6:35 pm
I done the samething with the inlet and it's been fine, just got to change the Temperature sensor and all should be well :D
Jem
Post Mon Nov 07, 2005 7:05 pm
I'm hoping new inlet manifold gaskets and a good check of ALL the vacuum pipes will sort it. There is clearly a leak some where. I think it's where the manifold meets the head for cylinders 1 and 2, as the idle picks up and smoothes out when that area as swiming in carb cleaner.
Would it be worth running a bead of slicone based 'instant gasket' on both sides of each gasket, or is it better to use the gaskets dry?
Post Mon Nov 07, 2005 7:14 pm
If you go back to the start of this thread, you'll find this.
Instant gasket shouldn't be needed with new gaskets on clean surfaces and properly torqued.
The inlet gasket failure on one of my cars I posted about a couple of months ago was caused by the engine having been rebuilt a year before, and a nut left completely off. (I have names!)
Jem
Post Mon Nov 07, 2005 8:14 pm
Yeah, I know you posted that, and it was the first thing I did check. Clearly I didnt check it enough. I'll have the gaskets on Thursday. If it is a vacuum leak, I'm not worried about the cost of the bits I have replaced, as they were in need of changing anyway.
Jem
Post Wed Nov 09, 2005 2:14 pm
It's Fixed!!!! :D :D
Once I took the bottom half of the inlet mainfold off, it was very clear what had been causing the problem. The inlet manifold gasket looks like it had sliped when it had been fitted buy a previous owner/garage :roll: . It was very missaligned round the port for cylinder 1 :roll: Also looks like the injector had been firing directly at the missaligned gasket. I cleaned up the head and manifold surfaces, bolted it all together with new gaskets, and now it's smooth as silk :D
Big thanks for all the advice guys :thumb:
