engine question
jimbob29
can alot of short journys and stop start traffic never really opening the throttle ect cause the car to smoke once i get the chance to opening her up our roads are crap and our only dual carriage way is 1/4 mile long lol
Short journeys are not good for any car, and by far the greatest amount of engine wear occurs in the first couple of minutes from cold, especially on cars that most of you insist on running on petrol.
Check that your cooling system is in perfect order, with a thermostat that doesn't leak, so that the engine gets up to full temperature as soon as possible, and check that the enclosed section on the underside of the rocker cover that connects to the breather hose stub isn't full of gunge.
Apart from that, your smoke is probably due to a bit of engine wear.
