New under steering column panel
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Mon Nov 07, 2005 12:16 pm
I've just picked up a new panel to go under the steering wheel, and there is a cutout for the headlight adjuster, but there is no provision made for the OBC gong, is this normal and I have to cut it out myself or have I got the wrong part again?!!
thanks
:thumb:
ian332isport
Mon Nov 07, 2005 1:58 pm
William wrote:I've just picked up a new panel to go under the steering wheel, and there is a cutout for the headlight adjuster, but there is no provision made for the OBC gong, is this normal and I have to cut it out myself or have I got the wrong part again?!!
thanks
:thumb:
William,
Have you had a close look on the inside of the panel ? It's possible that the hole is already marked or partially cut already.
It's probable that you have the correct part, but the OBC was optional, so the hole would normally only be added if the OBC is fitted.
Cheers,
Ian.
William
Mon Nov 07, 2005 2:35 pm
Thanks Ian, yeah the wadding/foam stuff is scored with the shape of the gong, but I haven't actually taken it off to see if the actual panel is scored on the inside, its not scored on the outside though. Glad to hear that's normal, should I use a stanley knife to cut the panel or do I need a saw?
thanks again
:thumb:
ian332isport
Mon Nov 07, 2005 2:39 pm
William wrote:Thanks Ian, yeah the wadding/foam stuff is scored with the shape of the gong, but I haven't actually taken it off to see if the actual panel is scored on the inside, its not scored on the outside though. Glad to hear that's normal, should I use a stanley knife to cut the panel or do I need a saw?
thanks again
:thumb:
William,
I think a good sharp stanley knife should do it. May be worth running a small drill through the 4 corners before you cut to help stop you going too far.
Ian.
William
Mon Nov 07, 2005 2:41 pm
Will do Ian, thanks for that. Will let you know how I get on
:thumb:
Simon
Mon Nov 07, 2005 4:20 pm
William, when you ordered the panel, did they supply it on your chassis number, or did they just ask what car and took a guess when ordering?
They should have asked if your car had an OBC, headligh adjust or airbag IIRC, you would have had the correct panel (with cutout) then.
If they supplied it on your chassis number, then it maybe as Ian says the OBC was fitted at a later date.
William
Mon Nov 07, 2005 4:25 pm
Hi Simon, it was done on the chassis number but even then they asked me whether I had headlight aim control or not, so I don't quite know why they bothered being specific about the chassis number?? The cutout is scored so I will try and see where we get to!!
thanks
:thumb:
robmpulse
Sun Apr 30, 2006 6:14 pm
headlight adjusting control?
What's this, aside from the obvious.......
is it electric or pulley based?
does anyone have a pic of the control in the dash?
Simon
Sun Apr 30, 2006 6:24 pm
robmpulse wrote:headlight adjusting control?
It adjusts the beam up and down to avoid dazling oncoming traffic to counter different weights in the car, was a totally useless hydraulic system, that very rarely works!
Demlotcrew
Sun Apr 30, 2006 6:27 pm
Simon wrote:They should have asked if your car had an OBC, headligh adjust or airbag IIRC, you would have had the correct panel (with cutout) then.
And climate control.
Andrew
toby
Sun Apr 30, 2006 7:31 pm
I bought a new one of these panels and was disappointed with its quality and finish and it isn't quite shaped correctly to fit the fourth fixing on the underside of steering column.... winge ... winge....
beardymat
Sun Apr 30, 2006 7:40 pm
i bought a new one from the dealers about 2 months ago.asked if i had obc or headlamp aim and the part arrived with the appropriate amount of holes,didnt have a problem with the fit though
not exactly the end of the world having to cut out holes in e30 parts as most are scored or marked, even the hole in the bulkhead for the aircon pipes is pre cut and just needs popping out.cant get over how well thought out these cars were
keith52
Sun Apr 30, 2006 7:43 pm
Whats the going rate for a new panel ? Cheers Keith
Simon
Sun Apr 30, 2006 7:55 pm
keith52 wrote:Whats the going rate for a new panel ? Cheers Keith
I paid £33 from trainers.
keith52
Mon May 01, 2006 9:08 am
Cheers Simon
