The temperature gauge on my moredoor 2.5 is playing up, basically it fluctuates, when driving along it stays pretty much a needles width below half way, when stationary it tends to creep up to about a needles width past half way, I thought maybe the viscous had died but even with a new one It's no different.
I'm thinking maybe the sensor is playing up, any thoughts???
Temp guage issues
powelly
Le Mans Classic 2006-
Sounds like things are working exactly as they should!
e30-EVN
yep +1, only worry if the needle approaches 3 quarters!! anything from half to there is only a few degrees and looks more on the guage than it actually is
powelly
I guess I'm just being paranoid, the gauge used to be rock steady that's the only reason I raised the question.
- **BANNED**
Could be the first signs of the radiator starting to loose efficency,a few furred tubes reducing both capacity and the ability to pass air when the fan is working.
You do have a fan shroud fitted?
Youth is wasted on the young.
The slight increase in temp. is what engages the viscous coupling to switch on the fan.
powelly
[quote="daimlerman"]Could be the first signs of the radiator starting to loose efficency,a few furred tubes reducing both capacity and the ability to pass air when the fan is working.
I only changed the radiator about 3 years ago, in which time It's done about 5000 miles.
I think I'm just being paranoid to be honest.
