I could really do with knowing where the throttle body connects, trigger sensor, etc as i've got a load of 3 pin connectors and you can't really tell what goes where - if anyone has a picture of a loom spread out with indicators as to what goes where that would be really useful.
Some areas i'm stuck on are pictured below, for instance i don't know what relays i need?
This round connection comes from the oil level sender (well I think that’s what it is in the sump) but I don’t have this connection on the loom anywhere?
I also have spade connector that is near (but I don’t think apart of) the starter motor wiring ”“ it comes out of the main thick part of the loom but doesn’t exit the loom in the same place as the thick red power and the black yellow solenoid wire. Any ideas what this could be for?
For some reason i have two spade connections from the injector loom, one is a white red wire and the other is yellow and brown i think - does anyone know what these are for?
I’m really sorry for all the questions but I really hope you can help, i think I’ve figured out the wiring to the fuse box so I think it’s just these little bits and bobs left to finish before I can try and wire her up.
Regards
Andy.
