Guys
I have been reading about the 6 and 13 button OBC's. I don't need all the MPG stuff etc, but an outside temp would be good, so am thinking about a 6 button.
Question-does it have an alert for ice warning?
Is the 6 button easy to fit?
Thanks.
6 button OBC-ice warning?
rover-2000
Kind regards
John
1989 320i Touring
1993 E34 525i SE Touring
1979 Porsche 924 Lux
1982 Porsche 924 Lux
1985 Porsche 944 Lux
John
1989 320i Touring
http://www.e30zone.net/e30zonewiki/inde ... d_Computer
Useful guide to fitting.
only one of the 5 E30's I've owned had one fitted - and I can honestly say that the only function I used was the clock
if you're going to go to the trouble of fitting one you may as well fit the 13 button
mb15
The Temp sensor is also prone to failure as is the wiring that connects it. When it is faulty the obc gong will beep everytime the car is started and read -22c on the display letting you know it thinks it is cold when it isn't! Bit annoying
Worth asking if the whole set up is fully working before spending out for the kit.
